Old 10-22-2016, 06:44 PM
arneyz arneyz is offline
Default Clearing out empty space at the end of a session
This is a problem I keep running into. I think maybe it happens when I scroll out too far, but the size of the session ends up being on the order of 90 minutes.
I'm not talking about my bounced files. Just the size of the session window. I've attached a photo to illustrate. You can see my session occupying the first millimeter or so on the left end of the window and then there is just an open universe of like 5000 bars. The problem is when using things like tab to transient or simply truing to scroll to the end of the session, I can overshoot it by a lot and end up confused and wasting time scrolling back into the session and finding my spot.
Is there a way to clear this empty space so that my session window is of reasonable size again?
File Type: jpg Screen Shot 2016-10-22 at 8.37.03 PM.jpg (70.7 KB, 0 views)
Old 02-15-2017, 03:34 AM
Soundburst Soundburst is offline
Default Re: Clearing out empty space at the end of a session
If you go to Setup -> Session - then choose SESSION LENGTH and make it 06:00:00:00 (the minimum allowed by Pro Tools.
Unfortunately you can't have less than that.
Old 02-16-2017, 08:42 AM
Carl Kolchak Carl Kolchak is offline
There's probably an errant automation node somewhere along the timeline.
Put the cursor in the ruler at the top (so that it selects across all tracks), after your program material had finished - leaving space for reverb tails etc - and hit :
Mac = Command Shift Enter
Win = Ctrl Shift Enter
To select from the cursor, right up to the very end of the session, and hit delete ( if that doesn't work, instead of hitting delete, go to the edit menu, and use the "clear special" > all automation option).
Can´t get cloud storage space back when clearing clips i clip list? surstromming Avid Cloud Collaboration 8 04-01-2016 11:05 AM
clearing unused regions/disk space jameynate 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-20-2007 11:08 AM
Mr. Administer,, there is only an Empty Space STAR NINE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-17-2005 09:04 PM
Clearing empty space from end of song cruisemates 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 09-19-2004 08:30 AM
How to delete empty space? 22down 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-28-2003 11:57 AM
