DIY Bass Trap Help!
So I am looking into the most cost effective/ best quality way to make some DIY Bass Traps. As I stand right now, I am going to be purchasing some mineral wool and building a few bass traps that way.
I have a few questions for anyone willing to help. 1) does it matter the type of traps placed on various surfaces. (corners, adjacent walls, ceilings) or can I just make the same design and place it at the problems spots? 2) Is it better to have 4 inch thick rather then 2inch? 3) most importantly. I found this: http://www.homedepot.com/Building-Ma...atalogId=10053 Does anyone think this would work inside of a panel if compacted well? It claims to have acoustic properties and is a fiber. Any thoughts? |
Re: DIY Bass Trap Help!
2) depends on use, placement, insulation material, etc. 3) that's blow-in insulation, NOT what you want... Google do-it-yourself acoustical traps, you'll find tons of designs and details. You'll also find outlets for the types of rigid insulation you'll need
"Sometimes having limits keeps you sane"- Albee1952 |
Thank you guys for the quick response. I will continue to research this topic so as to maximize my extremely tight budget!
Send me a message thru my profile, and I can send you a pdf step by step instructions for building bass traps. I found it thru JohnSayers.com (the ultimate resource for all things acoustic...everything you ever wanted to know and then some)
I just built 10 of them for pretty cheap.
003r/i7-930/LE 8.0.1 cs2 on xp |
I guess I don't understand why the "Blow in" fiber won't work. If I make a frame for it, a way to hold it in, and compact it, why wouldn't it work? It is mineral wool, the same as the mineral wool board.
as nasty as glass is to work with mineral wool is worse
you'll never get as even a pack with blown in as you will rolling bats to fit
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
A frame rigid enough to hold this type of insulation in place would be acoustically reflective, not allowing the sound wave to enter the insulating material.
http://www.gearslutz.com/board/studi...ing-acoustics/
Lots of info here. A couple contributors are acousticians, too, so you can weed out some actual pro advice. WARNING You may begin too feel your room is sadly under-treated after reading some of these threads. Often, the advice seems to be to spend more $ on the treatment then on actual gear and that's a hard one to swallow..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Selby ART Bass Trap- any good? | Luke K | General Discussion | 2 | 04-13-2011 08:39 PM |
what studio trap is this? | vdz | General Discussion | 0 | 02-16-2007 02:07 AM |
Bass Trap for a sub woofer | 6969 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 03-01-2003 06:45 AM |
unimplimented trap...help???? | Rader Ranch | Pro Tools TDM Systems (Mac) | 6 | 05-30-2002 10:24 PM |
Building a bass trap | JLEpperson | General Discussion | 1 | 06-30-2001 12:32 AM |
