Old 01-10-2011, 02:29 AM
eurovision eurovision is offline
Default Soundminer and ProTools workspace
Hello all,
What is the correct "info field" in soundminer pro to enter file description data so that it´s visible also in Pro tools workspace/search engine?
Maybe a simple question...still learning the program
Thanks.
MacPro 2x2.66 GHz, 8GB, 10.7.5, PTLE 9.0.6, Mbox2Pro
iMac 27" 3,5GHz i7, 32GB, 10.9.3, PT11.2.1, HD Native Thunderbolt
Old 01-10-2011, 03:37 AM
Default Re: Soundminer and ProTools workspace
Originally Posted by eurovision View Post
Hello all,
Thanks.
Anything you spot to PT with soundminer will carry the PT-readable long name (the "file comment" field in PT). No need to prepare that in SM manually.
PTHDn 2021.12 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron
Old 01-10-2011, 03:49 AM
Thanks Frank, but in this case I´m preparing a bunch of files for a sound FX library and I´m creating/entering all sorts of metadata in Soundminer.
Sorry for being unclear.
New to the Soundminer is what I meant.
Old 01-10-2011, 03:54 AM
The most commonly used meta-data fields are the BWAV fields in SM they can be read directly by most apps. The SM fields are proprietary.
What I do is use the powerful admin window to batch-copy any of the fields to the any of the BWAV fields after entering all the info.
Read the "Metadata Advanced" section of the SM manual for further info.
Old 01-10-2011, 04:04 AM
Thanks!
Old 01-26-2011, 01:20 AM
crg crg is offline
Just a FYI....Soundminer will automatically add whatever is in your Soundminer 'Description' into the BWAV BEXT description upon transfer. In other words, if you use SM to make or copy out to WAVE format, the data will get filled automatically, but if you want more control over what goes into that container, you can use the many advanced features in v4pro to combine field info and put custom content in the BWAV bext description as Frank noted. Also SM when it outputs to AIFF fills in the metadata so that iTunes can see it as well.
HTML code is On
ProTools Edit Window Disappears With Soundminer Spot to Timeline chadjhughes macOS 1 02-25-2014 06:51 AM
Soundminer v4.1.8.27 not playing back in protools 8 digartisan Post - Surround - Video 6 06-20-2009 01:38 PM
Soundminer 3.2LE & Protools 7 argot Post - Surround - Video 7 07-24-2006 07:38 AM
Soundminer crashing ProTools on Mac OS10.3.9? muselemuse Post - Surround - Video 3 06-04-2005 12:22 AM
