Old 03-02-2008, 03:21 PM
jsmithington jsmithington is offline
Default Question on Instrument Tracks
Is it possible to have multiple MIDI lines in a single instrument track triggering different channels of the plug-in, or do we have to use individual MIDI tracks?
Thanks.
Old 03-02-2008, 05:48 PM
Default Re: Question on Instrument Tracks
According to the Reference Guide, yeah, Start-click the MIDI Output selector.
filosofem
Aaron Mulqueen - 001 HD Native
Old 03-02-2008, 07:26 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
as many as the indtrument plug allows, u can open in PT...for ex, the Motu has an A,B,C, & D with each having 16 channels so u could open 64 midi channels in PT & go to work....
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 03-03-2008, 12:35 PM
whateverwrks whateverwrks is offline
im having problems with instrument tracks...can somebody walk me through really quick how to record from reason in to protools...I open the midi or instrument track...use the rewire...but then when I try to record nothing happens....can somebody help?
Old 03-03-2008, 01:30 PM
ok but u gotta pay close attn bud-deee...Open an instrument track(s) & midi of course...open a reason/rewire on the instr. track...(GO DOWN TO THE BOTTOM LEFT CORNER OF THE MIX WINDOW & OPEN THE WINDOW WHERE U CAN SELECT WHETHER TO VIEW INSTRUMENT, INSERTS, SENDSA-E, SENDS F-J, TRACK COLOR, COMMENTS....CHECK INSTRUMENT{not the arrows but the view icon}) @ the top of the mix window u'll see "ALL"-"NONE" etc...(on the instrument tracks only)...where u see "NONE", select that & you will see the different Virtual Instru. as well as instr. u've ALREADY open/created in REASON....select accordingly...u actually don't even need to use midi tracks doin it this way...ALSO make sure that ur MIDI THRU is checked in the OPTIONS in PT...if ur midi is set up correctly then there u hav it...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 03-03-2008, 07:03 PM
Hmm...I tried start-clicking and it seemed to select *both* MIDI channels, which would send the same MIDI line to both channels. I want to have different MIDI sequences triggering different channels of the instrument. Possible?
Old 03-03-2008, 11:19 PM
Yes but the MIDI device needs to be Multitimbral.
filosofem
Old 03-04-2008, 06:40 AM
The plug-in is multitimbral. I don't see how to write/record different MIDI lines in a single instrument track, though.
Old 03-04-2008, 09:35 AM
SeedGuy SeedGuy is offline
You can't, you need to create 1 instrument track with the plug-in instance on, this instrument track input will be plug-in 1+2 by default, and you cant change that.
Create another instrument track,
change the MIDI output to channel 2 of your plug-in,
channel 2 output of the plug-in to (usually) output 3+4,
then the input of your instrument track to plug-in > 3+4
Continue to do this with the amount of tracks you want.
Old 03-04-2008, 09:55 AM
Bummer, that's the way I do it now with MIDI tracks. I was just hoping there was a way to consolidate all MIDI tracks that point to the same intstrument into a single track. Thanks for the help.
2 instrument tracks each controlled by different MIDI input/instrument Midimax Pro Tools M-Powered (Win) 0 03-20-2012 03:10 PM
Dumb Question about Instrument Tracks Extramission MIDI 4 05-06-2009 02:01 PM
No Instrument Insert on Instrument tracks Bazbo Virtual Instruments 4 03-01-2007 06:00 AM
Question about instrument tracks johnnyv Pro Tools TDM Systems (Mac) 5 05-14-2006 01:41 AM
7.0 Instrument tracks question tonedef 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-16-2006 02:00 PM
