Old 07-02-2025, 09:45 AM
johnsongs johnsongs is offline
Default HDX + Apollo Workflow?
Hi All,
Was watching this clip: https://www.youtube.com/watch?v=1rt9tDwS9TI
Which is Suzy Shinn demoing the new splice integration.
I couldn't help but notice she is working with hybrid engine -- but has an Apollo clearly getting signal in the background.
Does anyone know how this studio is set up? Are those two interfaces setup to work together?
I happen to have both a Carbon and an Apollo and a setup like this would interesting to me.
I've tried just taking the ADAT inputs from an Apollo before -- but there is an inherent delay you have to account for which makes it almost not worth the extra effort.
Anyone (maybe with knowledge of that studio) have any insight?
Thanks!
Old 07-02-2025, 11:23 AM
[email protected] mradlauer@gmail.com is offline
Default Re: HDX + Apollo Workflow?
My guess is that she's using Apollo for more I/O. That's how I would do it.
In my little studio I have a Ferrofish A32 that sits in front of my Carbon.. SO all of my I/O goes to the A32 then out to the Line In and ADAT i/o on carbon to give me 24 channels at 48k. I feed all my I/O with a Heritage Super8, Cranborne 500 rack and a few other rack pre's.
Inputs:
Preamps --> A32 --> Carbon --> Computer.
Output:
Computer --> Carbon --> Heritage RAM 2k.
I track drums with Hybrid Engine... and fold back thru PT/Carbon with zero latency. I mean it's almost like recording on a console.
For example, my last session was 17 drum mics, a 2 channel stereo track and a printed click track... Everything has hybrid engine enabled.. zero latency.
I don't know if this answers your question but this setup works REALLY well for me.. and gives me tons of flexibility. To the extent that I can bypass carbon all together if I need/want too.. I also have patch setup to go directly into carbon pre's if I need them.
Old 07-02-2025, 01:13 PM
tope d's Avatar
tope d tope d is offline
Default Re: HDX + Apollo Workflows?
Hi there!
Might be a parallel setup, and not a fully integrated one.
Here how it's likely being used..
1. Carbon is being used for:
Main recording path
Low-latency tracking via Hybrid Engine
Direct AAX plugin monitoring
2. Apollo is likely used for:
Additional I/O (via ADAT or independently via CoreAudio for other DAWs)
Monitoring or external synths/instruments routing
Possibly Console FX or print paths outside of Pro Tools
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 07-02-2025, 02:55 PM
Inputs:
Output:
Awesome that’s good to know! How do you handle latency? By my calculation, running the Apollo and taking the ADAT inputs from it introduces about 220 samples.
Old 07-02-2025, 03:07 PM
Originally Posted by tope d View Post
Hi there!
Main recording path
Thanks for this! If I take:
Preamp -> Apollo -> ADAT OUT Apollo -> ADAT IN Carbon
And record one of those ADAT channels I seem to get about 4ms of latency, which I assume is coming from the Apollo's processing and A/D conversion. Maybe it comes from the input delay compensation on the Apollo hardware?
Old 07-03-2025, 09:41 AM
This is essentially my setup with A32/Carbon.. with hybrid engine latency is almost un-noticable.
If I turn off hybrid engine there is a an audible delay.. unusable
Matt Radlauer
Owner Clear Cut Audio LLC
System:
Ferrofish A32
Avid Carbon
M1 Mac Studio M1 Max - Latest OS
PT Studio (Current Version)
Old 07-03-2025, 10:31 PM
Have you ever measured the latency added by adding it over ADAT? Maybe your interface is faster but without all the magic using the Apollo as the main interface the ADAT latency is kinda high…
Old 07-04-2025, 12:45 AM
LDS LDS is offline
~4ms sounds about right. 2.2-3ms for UAD console, 1.7ms for Carbon. It’s the worst of both worlds when you consider a modern native system with UADx plugins can do better, with less restrictions on plugin count related to DSP power.
I wouldn’t rule out the hybrid engine presence being due to a paid Pro Tools promotion. She has been a UAD user for a long time. Maybe she transitioned to HDX, but keeps the Apollo around for UAD plugins. Might not even be her studio! In either case, you’d be better off sticking with either UAD or Carbon rather than mixing them for most applications…
Pro Tools Ultimate 2024.6. OSX 13.6.6. Win 10. Avid Carbon. Lynx AES16e. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 07-04-2025, 06:52 AM
You can't take anything from that, it's a Promo.
One YT comment says it's Sound Factory. Looks possible to me...but I've never been there.
Could be PT doing the work through HDX or Carbon with an Apollo recording the session separately for the video. No way of knowing.
Dominic
Old 07-04-2025, 10:07 AM
I haven't done any measurements.. I suppose I could. I was surprised at how bad the delay was when hybrid engine was turned off on my playback track.
TBH I never really spec'd out the A32 to use in this way. I've used Ferrofish stuff before for my location recording gig so I knew it was solid gear. When I was looking for a solution I wanted something that had enough I/O to run everything I have into one box.. Then I could take what I want out into Carbon. A32 has Dante as well, so I can bypass Carbon altogether without unplugging anything.
Matt Radlauer
System:
Ferrofish A32
Avid Carbon
FS: Apollo Twin MKII Quad, Apollo 16 MKII, UA 2-610, Studio Desk trackone Buy & Sell 0 02-14-2023 09:02 AM
Apollo 8Pre or Apollo 8 QUAD? Kerochan Third Party Interfaces 1 11-27-2017 11:08 AM
Pro Tools & Apollo Console workflow Tiboy Pro Tools 12 17 03-08-2017 02:25 PM
Apollo 8 and Apollo Twin Rosco1969 Third Party Interfaces 6 05-22-2015 07:53 AM
Workflow: Creating Film score music (template/setup/workflow) jhonny.eriksson Tips & Tricks 5 03-03-2015 10:08 AM
