Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 04-17-2024, 05:26 PM
GaryLGSimpson GaryLGSimpson is offline
Default Re: Sync HD Loses Connection With No Session Open
I'm at a large post house 175+ PT rigs. We have seen this on many systems as well. I suspect it has to do with major Mac OS updates. Many of our systems were originally on Mac OS 12.7.4 (Monterey) and have been updated to 13.6.3 (Ventura). Systems built from scratch don't seem to have this issue. I suspect it is some power management setting that is reachable after the upgrade. In many cases if you focus on another app or Finder it will come up. We have to use the lock screen for security purposes this will cause it too.
Old 04-18-2024, 04:11 PM
johnmichaelcaldwell johnmichaelcaldwell is offline
Interesting, originally these were setup from scratch in 2021. Perhaps it's time to wipe and restart, although, that's a fairly big annoyance to solve something relatively small.
I've currently resorted to leaving the System Usage window open all of the time and that's suppressed the issue. Would be great to see this fixed. I've been in contact with Avid Tech Support and kept them updated, provided all the logs, etc. They can't seem to figure out why and have also claimed I'm the only person that's experiencing this...
Old 05-21-2024, 09:46 AM
Halfmoon Halfmoon is offline
Not sure if this might help, but I found this in the PT Reference Guide:
Disabling Avid Audio Sever to Prevent Clock Disruptions with Sync X or Sync HD
(Mac Only)
When you quit Pro Tools, the Loop Master changes from Sync X or Sync HD to the primary audio interface in the system, and the HDX or HD Native Core Audio driver becomes the Clock Master for the primary audio interface in the system rather than your Sync X or Sync HD. These changes may disrupt audio outputs of Loop Synced interfaces or those following word clock generated by Sync X or Sync HD.
Disruptions are more significant if the Core Audio driver is set to a different sample rate than Pro Tools. Once Pro Tools is relaunched, the Loop Master and Clock Master revert to Sync X or Sync HD.
To prevent the Loop Master and Clock Master from changing (thereby stabilizing the clock) when
quiting Pro Tools, disable the Avid Audio Server.
To disable Avid Audio Server:
1. Locate Avid Audio Server at /Applications/Avid/AvidAudioServer.
2. Rename Avid Audio Server (for example, rename it to “#AvidAudioServer”).
3. Reboot your computer.
Tip: To revert to the default behavior, reinstall the Avid HD Driver and reboot your computer.
Old 06-06-2024, 11:15 AM
Just tried disabling the Audio Server and no fix.
Avid Pro Tools's tech team did get in touch with me about a month ago to say that they think they've managed to fix whatever was causing this issue and that it should be gone with the new release that comes out next.
S1 loses connection Jazzbass56 Avid S1, S3, Dock and Control App 24 01-30-2020 10:18 AM
PT 12 HD loses sync but only indicates in session window Nick Namnone Pro Tools HDX & HD Native Systems (Mac) 0 11-09-2016 10:44 AM
ModDelayIII loses tempo sync after reopening session clausiii macOS 0 05-30-2012 01:31 AM
002R Loses connection w/PT LE 7.3.1 badseed79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-09-2007 10:17 PM
001 loses connection mersisblue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-28-2004 08:47 PM
