Old 05-24-2010, 09:06 PM
lutherpilgram lutherpilgram is offline
Default ProTools barely works on new MacBook Pro..HELP
I'm totally livid.
I just spend $2K on a new MacBook Pro, installed the latest PT version 8.03....and it is very unstable. It freezes/hangs at various stages when I try and open up a file. I usually have to force quit many, many times (9, sometimes 20 times) before I can get a file to open properly. I'm using an Mbox 2 for the interface.
Anyone else have this problem? Anyone have a fix?
Old 05-25-2010, 01:29 AM
JazzyJ JazzyJ is offline
Default Re: ProTools barely works on new MacBook Pro..HELP
You really need to go through the steps here first:
http://duc.digidesign.com/showthread.php?t=193636
There are many possibilities that your problem could be, for example:
1) External Firewire Audio Drive fragmented - defrag or re-format
2) Non compatible plugins - move from used to un-used plugin folder
3) USB port / cable issues - try different cable and/or different port on Macbook
4) Bluetooth or internet interference when using - tun off Bluetooth and airport
5) Processors set to 2 (or more) - in Protools, set the processors in RTAS to ONE (this is massively important and could well be your solution).
Good luck.
Hack Pro (4.2Ghz i7 Quad/16GB)
PT11 / OSX 10.8.5
TC Electronic Konnekt 24D
Mbox 2, Input works, sound for non-protools works... rmiller9969 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-13-2011 04:13 PM
m-audio fast track pro no longer works with protools on my macbook pro! reals Pro Tools M-Powered (Mac) 0 07-11-2011 04:22 PM
THIS WORKS!! PT-Mpowered 7.1.1 and Macbook 2.0 OSX 10.5 bradwarren Pro Tools M-Powered (Mac) 1 02-25-2008 09:19 AM
MacBook Pro 2.4 / OS 10.4.10 / PT 7.3.1 LE WORKS PreBinding Floydio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-19-2007 10:50 AM
It Works! My Protools system works!!! Woooooo Hooooo!! Siberian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-19-2003 08:48 AM
