Old 01-09-2008, 06:53 PM
alw4416 alw4416 is offline
Default Working in session and PT just closes!!!
I have noticed a few times that I will be working in a PT session 7.4cs2 HD3 Mac Pro 10.4.8,9,10, and 11, doing nothing in particular when all of a sudden PT just closes completely, no crash, no warning, no SPOD, nothing! What is the story here? The only thing I can think of is that I have some virtual instruments instantiated like the Rob Papen stuff ie. Blue, Albino, or Predator. I really wish Digi would get their act together with midi and the like. PT seems to be very finicky about software instruments in general. I never have these issues with Logic and yet I want to use the PT elastic audio features. Anyone have any ideas? All my versions of plugs are the latest, have deleted all prefs etc.. ran the whole troubleshooting gamut and this stuff still happens...Very frustrating!
Old 01-09-2008, 08:23 PM
Lee Blaske Lee Blaske is offline
Default Re: Working in session and PT just closes!!!
Well, if you're convinced that the VI's are causing the problem, you might want to run them in AU within a shell on a second machine, where they'll either be more stable, or at least not bring down your PT session.
Have you checked to see if a crash log has been generated?
Old 01-10-2008, 01:47 AM
crizdee's Avatar
crizdee crizdee is offline
I am running PT every day with loads of various VI's and i don't get quits!!!! So it's NOT ">Digi who need to get their act together<".
If you're sessions are crashing then there's a cause! you need to start looking at which VI is the cause as i can almost guarantee you one of them will be causing the crash and NOT PT itself.
Crashing in 10.4.8,9,10 & 11? seems you've has some buggy VI in your plugs folder for quite some time. i'm sure you could pin point it down to one VI??
Try looking in Mack HD/Users/Your name/Library/logs/crash reporter/Pro tools HD and see if there's a crash log for the time your session crashed. there's usualy a thread that causes the crash and it usualy tells you which VI was the culprit.
Always make sure you have the most up to date version of the VI or make sure your version matches the version of PT you are using (there's no point using the latest version of a plugin if your version of PT is 2 years old etc!) so make sure all software is matched.
And for the record i am using 3 x Rob Papen VI's albino 2/3 and blue
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-10-2008, 09:08 AM
Howardk Howardk is offline
I have the same problem and from what I can tell it is Ivory and not Native instruments (for a change). Which VIs are you using in sessions that exhibit this problem?
...for system configuration info see my profile
(Click on member name)
Old 01-10-2008, 09:15 AM
There is absolutely no crash log. As I stated, PT didn't crash, it just closed out completely. It has to be one of the Rob Papen plugns. I too have NI and Ivory but not in this session.
Old 01-10-2008, 09:24 AM
DAS-Mike DAS-Mike is offline
I had this exact same thing happen to me last week in 7.4 cs2. I have since reverted back to CS1.
This was in a very simple session. I was using 1 instance of Stylus RMX. I have never seen this happen in the 15 years that I have been using ProTools. Specifically that the app just disappeared without any crash etc.
-Mike
Old 01-10-2008, 12:40 PM
Alécio Costa's Avatar
Alécio Costa Alécio Costa is offline
Guitar Rig also did that.
Alécio Costa Studio
High-End e-Mastering & Music Production
www.aleciocosta.com
http://www.facebook.com/alecio.costa
PT Ultimate Native 2023.3 - Mac Mini M1 16GB RAM - Mac Os Ventura 13.2 - 2 192 IO Digidesign Digital
PT HD2 Accel - 10.3.10 OS 10.6.8 - Mac Pro 2008 16GB RAM
Mastering Gear: Pendulum Audio, Crane Song, Avalon, Great River, Sebatron, Sonnox, Izotope, PSP, TC, Fab Filter.
Old 01-10-2008, 10:41 PM
jjamesbomb jjamesbomb is offline
I'm trying to run NI, BFD 2, Spectrasonics etc on 7.3.1cs5 on 10.4.10 and it's just the buggiest thing ever...it even crashed just now when I hit "about protools" to get the cs number...with no crash log...it's a joke for anything other than audio editing and mixing audio....forget about using VI with protools. Let's put pressure on Apple to make Logic rewire slave compatible so we can run all that in the background with protools...
Old 01-11-2008, 06:40 AM
crizdee's Avatar
The plugin does NOT have to be in the session to cause quits!!! every time you load PT ALL plugins are loaded into the cache ready for use. once you have found the culprit, your sessions should run trouble free 99% of the time. i run for months without unexpected quits, occasionally i will get a quit from a plugin, but i will troubleshoot it and if it can't be fixed i don't use it any more!!
No crash? what about a console log? in the same loaction as the crash reporter!!
I am using these VI's in this screen shot ...... http://i229.photobucket.com/albums/e...ee/RTASVIS.jpg
I'm not saying there aren't buggy VI's just that over the years i've learned to avoid them!
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-11-2008, 07:05 AM
It's pathetic isn't it? Think how scary powerful PT would be if it were stable with VI's! Are your listening Digi? Do you realize how buggy PT is with VI's? Can we work on this? I love PT for it's audio and editing capabilities, but it appears I will still have to use Logic to sequence. I really hope you are listening Digi. How about a response? Are you doing anything about these issues? I had it happen again last night where PT just closed for no apparent reason. Had some Rob Papen synths instantiated. No crash log, no log at all. This is unacceptable for the "king" of DAWs!
Cant Closes or save session noelooo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-07-2009 07:03 AM
Bouncing to Disk on Pro Tools LE 7.4 Closes Session?!? MitchM2006 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-06-2008 07:44 PM
Session Freezes and Closes Unexcpectedly rodrigosal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-26-2008 04:48 PM
PTLE 7 Crash: Unexpected Error: Session closes CalebB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-25-2007 08:48 PM
Ctrl - S (save) closes my session?!!?! SamuelAdams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-01-2006 10:18 AM
