midi clock from digi 001 with logic
I am trying to transmit midi clock from logic to my digi 001.
In synchronisation I selected transmit midi clock and selected the digi 001 port but it didn't work. Any ideas out there. Thanks Alec |
Re: midi clock from digi 001 with logic
The Setups>Peripherals>Synchronization window is to configure Pro Tools to Receive Sync.
In order to transmit MTC from PT LE, you need to enable "MTC to Port" in the Windows>Show Session Setup window and select the destination device in the port pop-up menu. If you are trying to transmit MIDI Beat Clock, you need to enable that in the MIDI>MIDI Beat Clock Menu. Any Devices in your OMS Setup that are configured to receive MIDI Beat Clock will be available in the window. Brent |
M box (digi design) not showing up in ''midi time clock'' | gotti gator | Pro Tools 10 | 0 | 04-06-2013 05:34 AM |
MIDI Clock Sync - Logic / Digidesign 002 | johnnmk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-16-2007 06:25 AM |
using digi 001's master midi clock | seasondigital | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-30-2007 12:12 PM |
DIGI 001 upgrade from 5.31 to 6.1 MIDI BEAT CLOCK | phinal1 | MIDI | 1 | 09-01-2004 02:06 PM |
digi 001 midi clock problems | soulshock7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 07-28-2004 11:28 AM |
