Closed Thread
Old 06-20-2007, 09:05 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools HD 7.3.1cs3 Update for Windows XP - Reposted
An updated version of Pro Tools HD 7.3.1cs3 for Windows XP is now available for download:
http://www.digidesign.com/index.cfm?...4&itemid=25129
Linked from the Pro Tools CS Updates page under Quick Links in the Support section.
In addition to all previous fixes, Pro Tools HD 7.3.1cs3 for Windows XP contains the following:
Fixed: Random Disappearance or Corruption of Regions On Tracks When Editing Or Punching In (Item #85976)
  • Although this could occur while editing or recording over regions, the problem was most evident when QuickPunching over existing regions.
Fixed: Importing Audio Files From A Sound Devices 744T Field Recorder Causes Multiple Problems (Item #90570, 90726)
  • Audio files would not have a Unique ID assigned to them
  • An assertion, "FF AudioProperty.cpp, line 33" would be thrown when overviews were being calulated
  • Audio could be unreadable by Pro Tools
Note: The following problem has not yet been addressed. We expect this fix in a future version of Pro Tools:
Pro Tools cannot access the time stamp information in Spot mode
Fixed: Attempting To Play From The Beginning Of A Session May Fail (Item #85674, 93283, 93289)
  • After the play command, the Play and Stop buttons flash, but Pro Tools does not play.
  • Repeated attempts may result in a successful play
  • Note: Pro Tools 7.3.1cs3 fixes some, but not all occurrences of this issue. Digidesign will continue to investigate additional fixes for this issue.
Fixed: Mojo SDI Could Not Directly Resolve To PAL Black (Item #90821)
  • Note that Mojo SDI would switch to "internal sync" when changing the video format in Pro Tools
Fixed: Error: "Digitize Aborted Due to Dropped Frames" When Digitizing to AVoption|V10, Mojo, or Mojo SDI (Item #91345)
Note: The fix covers most, but not all cases of this bug
This update is recommended for all Pro Tools HD 7.3 or 7.3.1 users.
If you downloaded the original version of this update posted on June 1st and removed June 7th, please download the newer version.
Administrator
Closed Thread
Pro Tools M-Powered 7.3.1cs3 Update for Windows XP Avid Pro Tools M-Powered (Win) 0 06-01-2007 05:21 PM
Pro Tools LE 7.3.1cs3 Update for Windows XP Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-01-2007 05:16 PM
Pro Tools LE 7.3.1cs3 Update for Mac OS X Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-01-2007 05:13 PM
Pro Tools HD 7.3.1cs3 Update for Windows XP Avid Pro Tools TDM Systems (Win) 0 06-01-2007 05:07 PM
Pro Tools HD 7.3.1cs3 Update for Mac OS X Avid Pro Tools TDM Systems (Mac) 0 06-01-2007 05:02 PM
