Closed Thread
Old 06-01-2007, 05:13 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools LE 7.3.1cs3 Update for Mac OS X
Available for download from the Pro Tools 7.3 and core system downloads sections, and the Pro Tools CS Updates quick link in the Support section: http://www.digidesign.com/index.cfm?...4&itemid=23300
In addition to all previous 7.3.x fixes, the Pro Tools LE 7.3.1cs3 update for Pro Tools LE 7.3 & 7.3.1 adds the following:
Random Disappearance or Corruption of Regions On Tracks When Editing Or Punching In (Item #85976)
* Although this could occur while editing or recording over regions, the problem was most evident when QuickPunching over existing regions.
Attempting To Play From The Beginning Of A Session May Fail (Item #85674, 93283, 93289)
* After the play command, the Play and Stop buttons flash, but Pro Tools does not play
* Repeated attempts may result in a successful play
Importing Audio Files From A Sound Devices 744T Field Recorder Causes Multiple Problems (Item #90570, 90726)
* Audio files would not have a Unique ID assigned to them
* An assertion, "FF AudioProperty.cpp, line 33" would be thrown when overviews were being calulated
* Audio could be unreadable by Pro Tools
Enabling Low Latency Monitoring Could Cause Loss Of Output Signal With a Pro Tools LE FireWire Audio Interface: 003 Family, Digi 002 Family , Mbox 2 Pro (Item #89073)
* Note that although the output signal would stop, the meter would still indicate signal present
Administrator
Closed Thread
Pro Tools M-Powered 7.3.1cs3 Update for Mac OS X Avid Pro Tools M-Powered (Mac) 0 06-01-2007 05:19 PM
Pro Tools HD 7.3.1cs3 Update for Mac OS X Avid Pro Tools TDM Systems (Mac) 0 06-01-2007 05:02 PM
Pro Tools HD 7.1cs3 Update Avid Pro Tools TDM Systems (Win) 0 01-20-2006 07:05 PM
Pro Tools 6.4.1cs3 Update for MIX Systems Avid Pro Tools TDM Systems (Win) 0 02-09-2005 07:59 PM
Pro Tools 6.4.1cs3 Update for MIX Systems Avid General 0 02-09-2005 07:44 PM
