I received a Left and Right track that's split into 2 mono audio tracks. How can I make these 2 files to 1 stereo file? Under "Track", I noticed that there is a "Split into mono" command but no "split mono into stereo". Thanks in advance.
PT Ultimate 2022.6 PT HDX MacPro 7,1 16 Core 96 GB ram OS X Big Sur 11.6 Somehow, musicians are now technicians! ![]() |
I don't think you can join two mono files unless they were originaly a stereo file that you split. So you may have to line them up, and mix them down to stereo on an additional stereo track. Wish I had more info for you, or maybe an easier step, but that's about all I can think to do. Good luck.
Due to budget cuts the light at the end of the tunnel will be turned off until further notice. http://www.gidakdigital.com |
if you just want to combine the split tracks:
Create a new stereo audio track, line the files up on two adjacent mono audio tracks and then you can make a selection across both tracks (Shift+click with the grabber tool on the two regions) and drag them onto the stereo track at the same time. Then you should be able to mix and bounce as if it were origionally one stereo file. If you have to do a lot of this kind of stuff, search the reference guide for "Export Regions as Files". Export Regions as Files can be used as a quick way to just combine split stereo/ multiple mono files when you don't need to mix or edit. -kirk |
Thanks for the informative tips! Now I can be creative again! Appreciate it very much
Keyboard shortcut - split stereo track into 2 mono | critza | macOS | 4 | 02-12-2013 02:04 PM |
How to split a stereo bus into 2 mono busses | zenstone | Tips & Tricks | 3 | 02-16-2011 05:05 PM |
Stereo EQ3 doesn´t split to mono | Frank Kruse | Post - Surround - Video | 0 | 04-15-2010 03:57 AM |
Split stereo into to mono | Nesp | Pro Tools M-Powered (Win) | 3 | 03-04-2010 12:03 PM |
What do i import a "dual mono" audio file as??? mono or split stereo? | peter parker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 07-17-2002 04:02 AM |
