Old 01-31-2017, 03:17 AM
markuse_23 markuse_23 is offline
Default Fades in 12.7 wiered
Dear all,
can someone confirm the behavior of fades? In "old times" (pt.11.3) I could just cut the tail of a clip and it was gone including the fades. Now the fades jump to the left to the new ending of the clip and messing around there.
This does not happen at the top of a clip. The option "preserve fades..." is switched OFF. Toggling it does not change anything in this behavior.
IF this feature "preserve fades" would work how intended (looks like a bug here for me) it would be just grat to have it in the OPTIONS menu in order to give it a shortcut through macOS.
Do I miss another setting or is it a bug here?
Cheers,
Markus
Old 01-31-2017, 09:51 AM
john1192 john1192 is offline
Default Re: Fades in 12.7 wiered
Originally Posted by markuse_23 View Post
Dear all,
Cheers,
Markus
hi markus, you do not say what version of PT or mac or PC .. BUT i tested here with 12.7 / Mac OS 10.9.5 and Fades are Working Correctly on head and tail of a Clip .. i have preserve fades turned off as well ..
cheers john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-31-2017, 09:59 AM
Oh, I am sorry...
OSX 10.10.5
MacPro 5,1 12cr 32GbRam
PT12.7.0 HD no DSP
Same Session in 11.3.2 on the same Comp work normaly.
Old 01-31-2017, 11:24 AM
Oh, I am sorry...
OSX 10.10.5
PT12.7.0 HD no DSP
corrupted session maybe ??? does it happen in a fresh session made in 12.7 ?? or just from older sessions ??
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-31-2017, 06:14 PM
kharp kharp is offline
I have seen the same issue. It doesn't happen all the time but when it does it seems to always be at the end of a clip.
If I select the area and choose delete fades from the menu, then it deletes it.
I also have the "preserve fades" option off.
PT HD 12.7 Mac OS 10.12.2
Mac Book Pro (Mid-2015)
Dear all,
Markus
Old 02-01-2017, 02:32 PM
Kirby B. Kirby B. is offline
I have seen this too.
12.7
Sierra 10.12.2 MBP (but happened in Yosemite too) and Win 10
Not a game changer, but annoying.
Digi002R PT2018 Win 10
INTEL Core i7 930, 3.52 Ghz
GIGABYTE GA-X58A-UD3R
CORSAIR XMS3 12GB 1600Mhz
2 X WD 1TB Caviar Black 64 GB cache
MOTU Traveller PT2018
MacBook Pro Mojave
16GB DDR3
Loud White noise fades on fades and dissolves! www Pro Tools 9 2 04-16-2013 09:59 AM
Replace all fades with dithered fades BScout Pro Tools TDM Systems (Mac) 0 10-31-2009 03:32 AM
Fades prefs vs. Batch Fades (or beating a dead horse) Starcrash Post - Surround - Video 2 09-23-2008 03:40 PM
create fades batch fades issue pt le theom Tips & Tricks 4 07-24-2006 09:46 PM
fades on muted regions render active fades?! yikes clarpark Pro Tools TDM Systems (Mac) 11 02-08-2004 04:49 PM
