Old 01-13-2011, 12:13 PM
Kurt Briggs Kurt Briggs is offline
Default Problems with Standalone ASIO Driver version 8 for 003R
I am posting this in both the Pro Tools and Pyramix forums as the driver is an Avid Digidesign driver but the problem actually occurs when using Pyramix. I’m hoping both forums will forgive the ‘third party’ flavor.
I recently upgraded to Pro Tools 7.4 for Mac. This is running fine on this platform. However, I also run Pyramix on a PC using the 003R. I have been doing this for 3 years without problems. On installing PT 7.4 the install program updated the firmware on my 003R and since then Pyramix has not been addressing channels correctly while recording. For example, Internal busses are recording onto the ‘live record tracks” when NOT routed to the main bus in any way or in the recording path. In other words, if I punch in to a third track where existing material exists ‘above it’ this original material finds its way onto the third track.
I decided that this must be an issue with the driver as a result of upgrading the firmware, so I downloaded the latest Standalone ASIO Driver—Version 8.03 from the Avid Site. After installing this to the PC I have had various problems:
1) Driver reported as missing by Pyramix software (Which means the program won’t load at all.)
2) Driver found by Pyramix VS3 Control Panel (in Windows XP Control Panel Menu) and version reported correctly—including correct Input/out and buffer, but still not found by the program itself on load.
3) Driver not found by Pyramix VS3 Check applet—which then crashes after reporting this. Even though reported by VS3 Control Panel immediately before.
4) Driver Install program adds older version of C++ Redistributable Files 8.0.56336 — I believe Waves or Pyramix has already added version 8.0.59193. Driver still not found even with either of these files deleted.
5) Unable to reinstall old driver as it will not recognize the interface. Even after uninstalling and manually deleting driver in system files and rebooting everything multiple times.
6) The Windows XP XP2 System won’t rollback the driver.
Has anybody had these kinds of problems and found the solution? I would be glad to hear from you ASAP.
Thank you,
Kurt
Old 01-13-2011, 01:03 PM
caruso7r caruso7r is offline
Default Re: Problems with Standalone ASIO Driver version 8 for 003R
To me it seems the last reliable version of asio from AVID was 7.4. You're not alone on this one. If you already haven't heard about this, there is an asio driver that might work for you called "ASIO4ALL". Check it out by clicking Here.
John
Pro Tools 12.5
Macbook Pro & Windows 7 Ultimate 64 Bit
Old 01-14-2011, 08:32 AM
Thanks for the reply John:
I tried the 7.4 driver but it wont install because I'm running XP SP2 and not SP3--I'm working on upgrading the system but for some reason I'm having problems there as well!
I also tried the ASIO4ALL but it seems to be a 2in 2out driver according to my driver software app inside Pyramix. Am I missing something? Maybe there is an 18in 18out driver somewhere on this site for the 003R?
Is it possible to reinstall the original firmware and still run PT7.4 or higher? If so, where do I get the firmware download?
Is the 003R ASIO driver working in Win7 yet? dwells Windows 1 10-02-2011 11:58 AM
Problems with Standalone ASIO Driver version 8 for 003R Kurt Briggs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-13-2011 10:39 AM
d24 / 888 IO / windows xp / standalone asio driver (7.3) zeh Digidesign Hardware & Software 1 04-28-2007 08:30 PM
PTLE Standalone ASIO driver simply refuses to work Statick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-13-2006 10:02 AM
Is the fully supported/non-beta version of the ASIO Driver released? oceandrive 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 07-09-2003 06:25 AM
