Artist Mix stuck on inserts
Hey people.
I just encountered this today, and thought I'd check withyou first, in case it's something easy, user error…, so I haven't done much troubleshooting, just a quick web search. I opened a session created not by me, and did my regular clean-up, reorganization, I/O etc. When I try to use my 2 Artist Mix'es to start mixing, I can't get them out of insert mode. When I click Pan or Aux or Group on AM, it just reverts to insert. I'm sure it's something stupid, so if you have an idea what might be happening, give me a shout. I'll start troubleshooting soon if there is no quick fix. It seems its only this session. Other sessions are fine without restarting stuff.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. Last edited by Ben Jenssen; 03-23-2023 at 01:50 PM. |
Re: Artist Mix stuck on inserts
Thanks for replying.
Yes it was all tracks. No channel mode, the CHAN button didn't work like all other buttons, all tracks just displayed the the name and the little 'a' for insert slot A. The only button that worked was 'Flip'. I switched between sessions several times, and this persisted on that one session. But the fix was very simple. I closed the session, powered off both AM's, opened the session and powered up the AM's. That was it. All good now. Thank you.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Next time can you try disabling EUCON in PT and reenable, see if that fixes it.
Artist Mix display stuck at maximum constrast / brightness | earhere | Artist Series | 22 | 10-31-2021 01:07 PM |
cycle inserts artist control/mix | espron | Artist Series | 2 | 12-09-2017 02:38 PM |
Artist Control won't boot, stuck on "Avid" startup screen [SOLVED] | emilano | Artist Series | 1 | 05-27-2015 05:26 PM |
D-Command Master fader stuck in Inserts mode | Jambroch | ICON & C|24 | 2 | 12-17-2012 12:23 PM |
Session load stuck at "activating inserts" | SoundtrackArcade | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 08-25-2009 06:18 PM |
