Old 03-29-2022, 09:44 PM
MixerGuy MixerGuy is offline
Default Sonnet Echo 3 Desktop power cable + AVID HDX power cable *together* ok?
I have emailed Sonnet tech support, but was wondering if anyone happened to have an answer to this question…. ?
I own a Sonnet Echo 3 Desktop. (PCI chassis) Have not used it yet.
I will use it with (most likely) one HDX AVID card
as you may know, over the years, AVID sent 3 different types of power connector cables with HDX cards. (the end that connected to computer came in 3 different sizes)
I don’t have the original AVID cable with the *small* connector that would fit into the Echo 3 Desktop….
However I *do* have an original AVID power cable that does seem to fit well into the much *bigger* 6 pin connector that is on the end of the supplied Sonnet cable. These 2 cables + connectors connected together are in the photo below. attached.
in other words: in the photo below:
the left cable is the supplied Sonnet power cable….. then in the middle it is connected to my (large connector style) AVID HDX power cable.
and on the far right are the 3 connectors that would fit into the HDX cards.
* note * in the middle there is one little plug that isn’t used at all, sticking up in the middle where the 2 cables join.
so - is this an OK configuration - to use these 2 cables together, to power my HDX card?
thanks for any thoughts.
Old 03-30-2022, 10:03 AM
Default Re: Sonnet Echo 3 Desktop power cable + AVID HDX power cable *together* ok?
Update 2 - a different Sonnet person basically said "it should work fine"
previously - - someone at Sonnet said "not supported, possibly not stable" in the method I suggested (photo above)
does anyone happen to know where i can buy a correct cable for HDX?
yes I know it came with the HDX card - i just need *another*, now.
thx.
Old 03-30-2022, 10:14 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Hi. The Sonnet uses the mini-6 pin to HDX mini 4 pin?
Old 03-30-2022, 10:27 AM
Originally Posted by MixerGuy View Post
Update - Sonnet said "not supported, possibly not stable" in the method I suggested (photo above)
thx.
I thought the cables came with the III? Can't remember I don't use HDX with mine and don't know where the cables are. But either way Sonnet sell exactly what you need. See What power cable do I need for the Avid HDX card for the Echo III, Echo Express III-D, III-R, or xMac Pro Server? at http://www.sonnettech.com/support/kb...tion=b939#b939
Old 03-30-2022, 01:03 PM
I am not smart enough to have an answer for you.
Old 03-31-2022, 10:15 AM
MCorbin's Avatar
MCorbin MCorbin is offline
The cables come with the HDX card. It's not uncommon for customers moving from a Mac with PCI slots to a chassis to not have tucked the power cables away for a rainy day.
That being said, you can get them from Avid and/or a reseller. If you look at the Chassis compato grid, we list which power cable part number is required.
https://avid.secure.force.com/pkb/ar...-Compatibility
m
Mark Corbin
Sr Principal Product Manager
Professional Audio Systems
For immediate assistance:
Pro Tools & Eucon Surfaces - +1 888-456-3444
Venue Support - +1 978-275-2557
Find out how to create, manage, and edit cases online now HERE
It's fast, easy, and effective!
Old 03-31-2022, 01:23 PM
m
thanks much.
Avid TB3 Chassis AUX power cable issue m.monty Pro Tools HDX & HD Native Systems (Mac) 8 03-18-2024 12:15 PM
Avid HDX thunderbolt 3 Rack power cable Nephew312 Pro Tools HDX & HD Native Systems (Mac) 3 06-20-2020 05:29 AM
Avid SYNC HD W/ Serial & Power Cable, $800 lucienpalmer Buy & Sell 0 09-07-2019 08:05 AM
Disconnecting Power Cable TerryBarnett Avid S1, S3, Dock and Control App 3 07-05-2018 02:28 PM
HDX power cable... mazarkill Pro Tools HDX & HD Native Systems (Mac) 5 03-27-2017 02:35 AM
