Re: 2021.6 Native - Dynamic Plugin Processing Broken
Confirming with 2021.6 Acon Digital Verberate and Phoenix Verb are running dynamically on tracks as expected.
So it means the plugins are compiled not to use the feature somehow? including AVID stock plugs? Quote:
Quote AVID's website: "The Dynamic Plug-In Processing option maximizes plug-in counts by dynamically reallocating host-based processing resources as needed. " From page avid.secure.force.com/Playback-Engine-Optimization Some plugin manufactures do bake dynamic processing into the code, Slate Acon, Sound Device Digital and Melda Production does it particularly well with a display in to upper right corner that shows when it is using CPU processing and when it hibernates(for lack of the proper term). Hats off to them. Their interfaces are a labyrinth to navigate, but they are efficient. As to the point of plugins not be coded for dynamic processing - that would possibly be the case if they didn't dynamically process when inserted in auxes. But they do. Every single plugin I have tested works as expected in aux returns. So the code to dynamically disable is in fact coming from Pro Tools and not the plugin. Again some manufacturers do bake it into their code and how quick they sense no audio and enter sleep mode varies from manufacturer to manufacturer. This feature does work in competing DAW's - Please Avid let me use the full power of my CPU - It is absolutely crazy that an audio track with plugins would be utilizing my CPU from start to end of a song even if there is no audio on the track at all or if there is one little sliver of audio for a big gong hit at the end of a song. AVID TECHS PLEASE: Create a session, make 32-64 audio tracks, put some stock plugins in, hit play and watch the system usage meter spike. Any HD native, Carbon or Ultimate users having this issue?
--------------------- Who is John Galt? Last edited by tmuzik; 07-08-2021 at 05:08 PM. Reason: typos |
Surely AVID's own pulgins should work properly. Politely requesting one of the MOD's to get any additional information from AVID.
Thank you. |
Still broken in 2021.7
Politely bumping. |
Escalating this big/issue to the team and lets keep this thread alive until this has been fixed.
It is annoying as heck not knowing if it works on one plugin but not another and having to look at that everytime is probably gonna get tired pretty quickly Since we run outboards 90% of the tile the few plugins we run doesnt work but our systems are working so we have not bothered with mocking around with DPP but I can see this would be a pretty lame thing for those of you using many plugins/
#16
Re: 2021.7 Native - Dynamic Plugin Processing Broken
Anyhow it was difficult to manage because all plugins were eating up the native processor regardless if there was audio - there might have been 3 tracks playing in the interludes but 77 empty tracks were gobbling the CPU - I know there are work arounds - we used them all - track freeze - audiosuite render - bounce down stems and sections... (time consuming - buzz kill) The point is, this is such an important feature of this wonderful DAW I love so much, especially as plugins get more cpu intense - please, please, please Avid can you look into this? _______________________________█████_____█████ _____________________________███____██_██_____███ ____________________________██________██__________ ██ ___________________________██__________█__________ __██ _______██████____________██_______________________ _██ ____███████████________██_____i LUV AvId___________██ ___█████████████_______██_______________________ ██ __███████████████______██____pLeaSe ___________██ __████████████████______██_____hELp__________██ __████████████████_______██_________________██ ___███████████████_______███_______________██ ______███████████_______██__██_____________██ __________███████______████___██_________██ ___██████__██████████████_____██_____██ _██████████████████████________██__██ ████████████████████_____________████ █_█████_████████████_______________█ __█_██__████████████ ____█__████████████ ______█████████████ ______██████████████ ______███████████████ _______███████████████ ______███████__████████ _____███████_____███████ ___█████████________██████
--------------------- Who is John Galt? |
#17
I was able to repro here so if you have (or start) a support case please reference PT-275441. Thank you.
#18
Fixed in 2021.10!
#19
Re: Dynamic Plug-In Processing is broken
#20
When I saw the update and reply to this thread I couldn't wait to update....
Is there a trick, click or setting that was introduced? The manual is still the same. The dynamic processing is still broken:-( See screenshot. 64ch - 88.2k - 256B - session pro MB - Comp - Exp on all ch's.
Dynamic Plug-in Processing | jkess | Pro Tools 12 | 6 | 09-04-2019 12:35 PM |
Dynamic Plug In Processing - 9173 etc. | T-Low | Pro Tools 2018 | 1 | 01-09-2019 01:22 AM |
HEAT + Dynamic Plug in Processing in 12.6 | T-Low | Pro Tools 12 | 0 | 09-29-2016 12:44 PM |
Dynamic Plug-in Processing Question | quantise | Pro Tools 11 | 1 | 03-13-2014 09:05 AM |
Is Dynamic Plug-in Processing messing up some VI's | Touchwood Studios | Pro Tools 11 | 2 | 11-19-2013 02:09 PM |
