Old 11-20-2010, 03:32 PM
K3DR K3DR is offline
Default Slow Playback
Weird Problem...Within the same file, I have regions that playback fine and other regions that have a slow dragging playback...I am not using midi inputs..nothing fancy..did I hit button the caused it...can I un-cause it..I hope
thanks
Old 11-21-2010, 01:12 PM
Julia B Julia B is offline
Default Re: Slow Playback
Did you do a tempo change with elastic audio engaged?
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz
IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte
L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh
Mainboard: DFI Inc. INF P35-R
BIOS : Phx Tech, LTD 6.00 PG 03/11/2008
Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus
MP APIC : Y
Tot Mem : 3.25GB DIMM DDR2 (WinXP)
Chipset: Intel P35/G33/G31 Proc
Front Side Bus Spd : 4x 266MHz
Mem Bus Spd : 2x 399MHz
(C:) : (250GB, SATA, 8MB Cache)
(D:) : (250GB, SATA, 8MB Cache)
Old 11-21-2010, 08:05 PM
I am so dumb that I may have it engaged and not know it... I will do some digging..thanks for your reply
How Can I Slow Down Playback? jtlaurie Pro Tools SE and Essential (Win) 4 02-08-2012 04:42 PM
Very Slow Playback mowgli789 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-26-2010 02:38 PM
slow playback Roshan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-24-2004 05:11 PM
slow playback muscmp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-25-2002 11:28 PM
Slow Playback willson General Discussion 2 11-29-2001 04:36 PM
