Old 09-26-2010, 02:38 PM
mowgli789 mowgli789 is offline
Default Very Slow Playback
Evening all,
I've scoured the forums and google to see if anyone else is having this issue, but haven't seen it yet.
Am running PT 8.04 with Windows 7. Seems to be going ok, and then all of a sudden, my play back suddenly goes really really slow. It sounds a little like a Darlik. I have tried changing my firewire cable, updating my firewire driver, turning off all of my plugins, and playing with the buffer in the hardware settings. Does anyone have any ideas?
Once it's turned slow, it appears to stay that way, and quitting and restarting PT only fixes it for a few seconds.
It maybe worth noting that the only way I can get my 002 to work in Windows 7 is to run PT 8.04 in compatability mode with XP SP3. This also means I can use my Command 8.
Any help would be appreciated as I am out of ideas.
Thanks
Ben
SiSoftware Sandra
Computer
Model : System Manufacter System Product Name
Workgroup : WORKGROUP
Host Name : BearLobster
User : Ben Wing
Processor
Model : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Speed : 2.4GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 1 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 2x 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing
Computer
Mainboard : Abit FP-IN9 SLI(C55-MCP51)
BIOS : Phoenix Technologies, LTD 6.00 PG 06/07/2007
Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 4GB DIMM
Chipset
Model : Abit Computer C55 Host Bridge
Front Side Bus Speed : 4x 267MHz (1GHz)
Memory Module(s)
Memory Module : Corsair CM2X2048-6400C5 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3)
Video System
Video Adapter : NVIDIA GeForce 8800 GTS 512 (Microsoft Corporation - WDDM v1.1) (128 SM4.0 1.5GHz, 512MB DDR3 2x972MHz, PCIe 1.00 x16)
Graphics Processor
Storage Devices
WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 466GB (C:)
SAMSUNG HD502IJ (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (D:)
PIONEER DVD-RW DVR-108 (ATA66, DVD+-RW, CD-RW, 64kB Cache) : 229MB (E:)
Logical Storage Devices
System Reserved : 100MB (NTFS)
Backup (D:) : 466GB (NTFS) @ SAMSUNG HD502IJ (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache)
Hard Disk (C:) : 466GB (NTFS) @ WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache)
OFFICE11 (E:) : 228MB (CDFS) @ PIONEER DVD-RW DVR-108 (ATA66, DVD+-RW, CD-RW, 64kB Cache)
Peripherals
LPC Hub Controller 1 : Abit Computer MCP51 LPC Bridge
LPC Legacy Controller 1 : Winbond W83627DHG
Audio Device : Abit Computer MCP51 High Definition Audio
Audio Codec : Realtek Semiconductor 888 High Definition Audio
Disk Controller : Abit Computer MCP51 Parallel ATA Controller
Disk Controller : Abit Computer MCP51 Serial ATA Controller
USB Controller 1 : Abit Computer MCP51 USB Controller
USB Controller 2 : Abit Computer MCP51 USB Controller
FireWire/1394 Controller 1 : NEC uPD72874 IEEE1394 OHCI 1.1 3-port PHY-Link Ctrlr
SMBus/i2c Controller 1 : nVidia MCP5+ SMBus 1
SMBus/i2c Controller 2 : nVidia MCP5+ SMBus 2
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : HP Deskjet D1400 series (1200x1200, USB, Colour)
Network Services
Network Adapter : NVIDIA nForce Networking Controller (Ethernet, 100Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Performance Tips
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
How Can I Slow Down Playback? jtlaurie Pro Tools SE and Essential (Win) 4 02-08-2012 04:42 PM
Slow Playback K3DR Pro Tools M-Powered (Win) 2 11-21-2010 08:05 PM
slow playback Roshan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-24-2004 05:11 PM
slow playback muscmp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-25-2002 11:28 PM
Slow Playback willson General Discussion 2 11-29-2001 04:36 PM
