Old 02-06-2006, 06:01 AM
KimSira KimSira is offline
Default Midi plays back wrong sometimes
Hi
I was working on a rather large arrangement (82 tracks) the other day, and sometimes I would hit play and my midi or more precisely instrument tracks would play out of time by about 1 bar. Sorry I can't be more precise as I was on the session and couldn't spend long on this. If I press stop and then play again straight away, all is good again. I think the main culprit was SampleTank SE, but can't be sure if it was just that one.
However, the MIDI only track that is sending to BFD on a seperate machine always played fine.
This is on a HD2 system with PT7.0.
I know this is really vague and don't expect to many answers, I was just wondering if anyone has come across this aswell?
Thanks
Kim
Old 02-06-2006, 07:26 AM
rockridge's Avatar
rockridge rockridge is offline
Default Re: Midi plays back wrong sometimes
Hi
You could try MIDI offset, and see if your sampler can keep up.
If that doesn't help, bounce half of the tracks so you're not dealing with so much MIDI.
If you don't want to deal with audio, simply cut MIDI tracks until you no longer get latency.
You might find that you don't miss the tracks you've cut.
Protools 10.3.10/11.3.2/12.6 | Win 7 Ultimate 64 bit
New Mbox plays back at wrong sample rate Gabriel_S 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 11-06-2010 11:39 PM
Drag/Import Audio Plays Back Wrong moogboy100 Pro Tools TDM Systems (Mac) 0 07-15-2010 11:59 AM
Samplerate issue: WAV plays back in the wrong tune ikke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-26-2005 11:57 AM
Transfer HD TDM to 5.1 TDM plays back wrong speed MarkB Pro Tools TDM Systems (Mac) 1 03-26-2004 06:32 AM
Pro tools plays back wrong audio David Carstairs Pro Tools TDM Systems (Mac) 2 06-28-2001 08:46 AM
