Old 05-13-2022, 03:21 PM
Default HD3 not using resources efficiently. Advice??
Got a simple session with around 36 audio tracks and 4 stereo AUX tracks.
All plugins are TDM(not a single RTAS plugin is in use)
Around 16 tracks are using sends to those AUX tracks for drum bus compression, room reverb, vocal reverb and delay(all plugins are stock plugins)
I keep getting playback stops with the error in screen shot and you can see the system resources window. It seems that things should be shared over the 3 cards, but it seems only the core card is actually handling anything and everything. Do I need to do something to force the system to spread the load over the 3 cards?
Session is on a separate 7200 rpm internal drive.
Session is 24 bit/48K
HD3 PCI cards in a Digi-branded expansion chassis
A single 192 IO is connected and all 16 analog inputs are working fine.
more system info:
G5 dual 2 GHz with 1.5GB RAM Leopard 10.5.8 and PT 8HD with license on gen 1 iLok.
500GB SSD system drive
160GB 7200 rpm drive for session(blank drive except for this session)
single 27" monitor @1920x1080(also tested with 24" monitor at several resolutions).
NOT connected to the internet for testing.
Tried copying the session to an external SCSI drive(15K rpm) but it was much worse)
HD3 PCI cards in Digidesign chassis(cards and 192 pass digitest).
Very new to Macs and HD systems(I have repaired disk permissions)
I am the admin and only account on this machine.
Old 05-13-2022, 03:23 PM
Default Re: HD3 not using resources efficiently. Advice??
Digitest OK?
Old 05-15-2022, 02:21 AM
LDS LDS is offline
From memory, you have a bunch of voice options available in a dropbox menu in the Playback Engine dialogue box. It looks like you have it set to only 48 voices, and have maxed them all out in your session. HD3 Accel should be able to run up to 192 voices, so I would try tinkering with that setting first.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 05-15-2022, 09:28 AM
I'll look for that and report back(fingers crossed!). Digitest did pass on everything.
Old 05-15-2022, 09:57 AM
LDS gets the virtual SM58 to drop But, things are still not quite as I think they should be, so I must ask more of my teachers:
1-I tried setting to 192 voices and recording still stops quickly(with the message about reducing RTAS plugins)
2-I tried 128 voices and recording went a little further, but still not more than a minute
3-I am confused about the playback buffer setting on HD. Should I put this to 1024(or higher), and does this setting cause audible latency?(a quick test with a mic and headphones suggests that it does not) If not, what would be the need for a lower buffer setting?(at 1024, recording goes off without a hitch)
4-the system usage window shows red on the 3 HD Engines; is this merely showing that all the resources are "available" or that they are all used?
5-should 4 Dverbs(2 are mono) really burn up 100% of the core card? And a single delay plugin burn up 99% of the second card?(new screen shot)
Old 05-15-2022, 10:05 AM
If the audio is staying fully TDM there is no IO Buffer use and no effect on latency.
IO buffer settings get used if you are going from the TDM to native world and back again. e.g. if you insert an RTAS plugin. No need to worry about it unless you are using RTAS plugins.
Old 05-15-2022, 03:02 PM
LDS LDS is offline
Like Darryl mentioned, the native sample buffer really only matters if you are doing stuff with native plugins. If you are just using TDM plugins, you can set it to 1024 with no issues.
Red just means 100% of a DSP chip has been allocated to tasks. I'm probably over-explaining things, but DSP isn't dynamically allocated like native CPU power is. If you choose the full EQ III TDM plugin but only use the high pass filter, Pro Tools will still allocate all of the DSP to run all of the other bands and and low pass filter just the same. For this reason, a lot of Pro Tools DSP plugins have a variety of derivatives. Like a 1-band EQ-III plugin, or 3, 5 and 5 + filter versions of the Sonnox EQ. If you only need 1 band, just choose 1 band as it will save DSP.
Generally time-based effects like reverbs will use a lot more DSP than frequency and dynamics based effects. The red HD Engine bars reflect the DSP assigned to your chosen voice count. By using that dropdown menu in the Playback Engine dialogue, you can tailor your DSP usage a bit towards your session requirements. Lots of voices, set the voice count high - but it means you will have less DSP for plugins. Less voices, set your voice count low - it will mean you can't run a lot of tracks but you will have lots of DSP for plugins.
There were some great plugins for TDM systems. Try and get your mitts on Waves TDM bundles, Audioease reverbs, Softube Tubetech plugs, etc.
Old 05-15-2022, 06:08 PM
Thanks to both for the great info! Last bits I will ask(and if you can't answer, I will test and self-educate). I am trying to get my hands on an iLok license for the Waves Platinum Ver. 5 installer that came with the package(sadly, the iLok itself was lost or stolen, and Waves put up a brick wall on support for TDM).
Last question re latency and buffer, I totally understand the issue with routing thru RTAS plugins(or mixing TDM and RTAS on a track) on audio tracks(and am okay with this limitation), but what happens if I want to use a handful of RTAS plugins, such as an RTAS reverb(on an AUX track with no other plugins in that chain), or an older version(RTAS) of Melodyne or AutoTune? With Dverb currently being the only TDM reverb, using my IK Classik Plate and Room is very desireable.
Great advice on the EQ plugin choices as I do have maybe 2 dozen EQ III instances going(half could be switched to the one-band version). I noticed(and was surprised by it) that I could use a buffer setting of 4096(which is not available on a native system at 48K) so I'll give that a try, too
Old 05-15-2022, 08:06 PM
And Aux track is a track without the part that bangs the bits to/from the disk, an Aux still lives in the TDM/DSP world and if you insert an RTAS plugin onto in they you are need to leave and return to the TDM/DSP world via an IO Buffer. And if you say alternate TDM and RTAS plugins on an Aux, they you cause multiple of those passages through the IO Buffer just the same as on an audio track.
Old 05-16-2022, 02:46 AM
LDS LDS is offline
You can use time based RTAS plugins on aux channels without much worry. Any additional latency just becomes predelay rather than any noticeable lag in time. Very few TDM reverb plugins ever became AAX-DSP for HDX because of that reason. Doing so costs you additional voices though - a voice isn’t just an audio channel in TDM/HDX. It is a pathway to/from DSP.
You can use RTAS plugins on any channel. If you record/input arm a channel, you will need to have a DSP plugin first in the chain otherwise the RTAS plugins will automatically be bypassed. Whether or not the latency is too large is something worth experimenting with.
Just be aware that round trips between DSP and CPU, or TDM and RTAS will cost you both in latency and voices. Sometimes it is better to keep a bunch of your plugin chain on a channel as RTAS for this reason, rather than moving audio back and forth between DSP and CPU.
How can I navigate between navigation points efficiently User_49 Getting Started 5 11-04-2020 03:04 PM
New playlists won't let me name efficiently scorchedwave Getting Started 4 06-10-2015 11:15 AM
Can I get someone to confirm that Bidule works with 8.0.4 efficiently? Violet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-13-2010 12:35 PM
Creating Loops Efficiently rennyren 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-09-2007 04:51 PM
Efficiently editing drums in LE spartacus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 04-16-2004 11:26 AM
