Two Aviom Cards
I have an application where one part of the band (large band) would use one 16 channel mix, and another part would use a different 16 channel mix..... Does anybody use two aviom cards like this?
Re: Two Aviom Cards
According to the Manual you can use up to three of the A-Net cards in one Stage Rack system, so you should be OK. Let us know how it goes.
Re: Two Aviom Cards
I do monitors on a show that uses 2 Profile 96 for monitors. I have 3 Aviom cards per system and it works like a charm.
Re: Two Aviom Cards
I also use 96 channels (2 stage racks) & have 1 A-net card in each stage rack for 2 different Aviom setups. A little time consuming if you have to change the patching every week but works like a charm.
Re: Two Aviom Cards
Looking to get 16 channels of analog audio for web cast. Told second a-net card with Aviom AN-16/o will give me +4 analog.. If I use a second A-Net Avid card, will it upset the 128 HDX which is feeding my ProTools?
Re: Two Aviom Cards
The input signals sent to Pro Tools are dependent on stage inputs, not outputs, so there will be no issues. You can have as many outputs (and types of outputs) in the stage rack or console (to the max supported) and it won't affect the connection to/from Pro Tools. Sheldon |
Aviom a 360 | amerikiwi | VENUE Live Sound Systems | 1 | 02-07-2013 07:50 AM |
Talkback to Aviom?? | bcash | VENUE Live Sound Systems | 2 | 09-05-2012 02:17 PM |
Aviom 49 I need help! | snoopdasnoopdog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-13-2010 10:28 PM |
Those of you using Aviom/PQ for ears... | timcorder | VENUE Live Sound Systems | 2 | 07-03-2008 10:20 PM |
Aviom ANET Cards | Scott Fahy | VENUE Live Sound Systems | 4 | 01-15-2008 12:13 AM |
