Old 12-11-2008, 06:16 AM
Bryan Talbot Bryan Talbot is offline
Default Random Pre-roll activation
Just thought I'd throw this out there to see if it catches fire. This is a bug that's been around for many years now.
Pre-roll will randomly activate out of nowhere, with some wild value like five minutes. It happens just once in a while, usually in the middle of rigorous editing.
I'm talking different systems on different computers in different locations over ten years' time.
Maybe fixed in 8? Well I can hope.
Old 12-11-2008, 06:30 AM
Default Re: Random Pre-roll activation
It´s probably just the shortcut you are hitting randomly.
Preroll on/off is apple-K.
frank.
Old 12-11-2008, 06:57 AM
remainanon remainanon is offline
I haven't seen this..
Could be an inadvertent option-click with the selector tool?
Old 12-11-2008, 07:01 AM
frank.
No it is not. I use that command deliberately. This happens completely at random, with utterly random values, and has been happening for ten years.
Old 12-11-2008, 07:06 AM
JMDNYC JMDNYC is offline
I'd just like to confirm that it happens to me, too. It's not the accidental hitting of Command-K, but it just pops up, and sometimes it has a very high value that jumps you to the beginning of a session. I'm ProTools 7.4.2 on 10.5.5, but it's happened in past version, too.
EDIT - I just did a little testing, and its true if you option click with the selector tool before where you're parked it turns on the Pre-Roll, and if you do it after where you're parked it turns on the post-roll. In other words: it's not a bug, its a feature.
Old 12-11-2008, 07:12 AM
studiojimi's Avatar
studiojimi studiojimi is offline
while we are mentioning command K
i thought i drop the keystroke reminder that "option K"
throws your record track input ON INPUT
really cool technique when recording a singer (or other instrument) that needs to hear themselves to get their pitch a little better during tracking.
really helps to move fast and on the job instead of mere mousing.
i mention this because i had not used it for a while for some reason and had a singer that a really needed it and this really quickly became and oldie but goodie for me.
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 12-11-2008, 10:53 AM
Very nice - thanks!
Thanks for that!
Old 12-11-2008, 10:57 AM
rdolmat rdolmat is offline
THAT is cool!! very handy!
cheers,
rich
Old 12-17-2008, 05:49 AM
PeterScherr PeterScherr is offline
Me too! Same weird behavior for years. And still here in 7.4.2! Since I'm always tracking when I do it, things are too busy to even think too much about it. I imagine that's why I never remember to mention it on the DUC. So What's up with this?
Old 11-16-2022, 05:09 AM
lode lode is offline
Wow! Old thread turned up on my google search!
Is there a way to disable this? I apparently misclick at least once every thirty minutes, and enable pre roll. I guess because I don't let go of alt while using it for some shortcut.
Newest Pro Tools on mac & pc.
Pre-roll/post-roll appears to be broken in PT10 anodecathode macOS 1 02-20-2012 01:33 PM
Pre-roll doesn't work but post-roll does :confused: pennard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-06-2009 11:26 PM
Pre roll and Post roll keyboard commands? Bob L 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-30-2007 07:46 AM
Roll up, roll up - Get your Free RTAS Plugins... Tanglewoodstu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 08-24-2005 09:46 AM
-9073 and -6086 DAE Errors RANDOM, RANDOM, RANDOM mikerica101996 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-13-2004 01:08 PM
