Mbox2 MINI control panel not showing up
I have installed Pro Tools 8.0, and then also updated to 8.0.5 to be updated properly for use with Windows 7.0.
I had to do a reinstall of Windows and now after installing all this, I no longer have a control panel for the Mbox2 mini....but do have 3 other control panels for the Mbox, Mbox mini and Mbox Pro. This means that I have Avid listed in program files with 3 separate folders for each of these with seperate control panels for each as well. They also all 3 show up in my control panel under sound devices... I am 99% sure this once showed only my Mbox2 mini in both areas. Any ideas how to resolve this please? |
Re: Mbox2 MINI control panel not showing up
Can anyone confirm if they have the Mbox2 Mini in their control panel under sound or if they have the Mbox2 Mini control panel in the Avid folder in My Programs?
Please? |
I have the MBox2 in Devices & Printers. It does not say "mini" anywhere even though that is what I have. I don't have an MBox2 Mini control panel in My Programs.
-- Mike - HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics - Windows 11 - PT 2021.12 - PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i - Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs |
And you havent had any issues despite this?
I havent gone through extensive trouble shooting to see if this comes up as a problem mind you, this is something I noticed and believe I once saw an interface where I could see the inputs (control panel) and feared I got the wrong drivers. Can anyone else also comment on this? |
These may be the best questions to ask..
Does ANYONE who has a "Mbox2 Mini" have a control panel for it listed in Programs, Avid? Also, do you have a "Mbox2 Mini" listed in the control panel under Audio devices? |
I have the SAME EXACT PROBLEM ....
3 Mbox's in my control panel - but worse than that ? The Mbox 2 Mini WORKS - but it's distorted. did you ever get your problem solved ??? because the Mbox Mini's that are showing up in my control panel. Are NOT CONNECTED and NOT STREAMING. BUT ? I can feed another input into the MBOX and it plays CLEAR AS a BELL. but MBox 2 MINI by itself is totally distorted .... |
Did you ever get your problem solved - with 3 Icons of Mbox in your control panel ?
Short for time atm, but let me know if you havent solved this issue on your end and ill let you know whats up.
Mbox2 Mini ongoing problem - NO control panel | Adwel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 29 | 04-11-2012 12:59 PM |
Mbox2 control panel | jjuhkam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-09-2011 08:03 AM |
002 Rack not showing as option in windows control panel (sound settings) | TheRealJayP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 12-08-2009 04:14 PM |
Mbox2 audio / midi not showing in windows control panel | kavs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-26-2008 07:26 PM |
mbox showing up as mbox2 and mbox2 pro | luckykid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-02-2007 09:13 PM |
