Old 06-21-2021, 07:31 PM
Tubthumper Tubthumper is offline
Default My plugin windows are black
Hi folks, long time no post.
I'm running Pro Tools 11.3.1 on Win 7 64 SP1 (don't laugh).
I had the PC built about a decade ago, it's still rock solid.
I'm having a problem with *some* plugins - after instantiation, the plugin window is black, and sometimes if I close the plugin window, PT will crash.
Other times, if I open a plugin (that had previously displayed with a black screen), PT will crash.
Any advice will be greatly appreciated.
Thanks
Old 06-21-2021, 11:22 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: My plugin windows are black
I think you need 32bit Windows or PT12
Janne
Old 06-21-2021, 11:28 PM
Thanks Janne, what do you think the issue is here?
PT12 is Win 7 64 bit only I believe (not Win 10)?
Old 06-21-2021, 11:29 PM
JFreak's Avatar
Compatibility info here.
Janne
Old 06-21-2021, 11:56 PM
Thanks Janne, I checked the compatibility chart, both PT11 and PT12 are compatible with Win 7 64 bit SP1, or so it seems.
PT11 is 64 bit only I believe.
Old 06-21-2021, 11:58 PM
JFreak's Avatar
Your OP mentioned 11.3.1 which as I read the chart is not supported on 64bit Windows
Janne
Old 06-22-2021, 12:11 AM
PT11 is 64 bit only, PT10 was the last version to run on 32 bit Windows
Old 06-22-2021, 12:12 AM
JFreak's Avatar
Sigh, don't get confused about 32/64 bit application and 32/64 bit operating system. You need PT12.0.0 or later if you want to use 64 bit Windows, you need 32 bit Windows if you want to use PT11.3.1
Janne
Old 06-22-2021, 12:15 AM
This is from the Avid Knowledge Base - Pro Tools 11 System Requirements:
  • Pro Tools 11 requires 64-bit Windows operating systems.
I've had PT11 running on Win 7 64 SP1 for years, no problems until the recent black plugin window issue.
Old 06-22-2021, 12:18 AM
JFreak's Avatar
Alright then, I stand corrected perhaps, Avid needs to revise one of the documents mentioned. What do I know, Mac-only guy.. just reading documents. The compatibility page says "Windows 7 SP1" for 11.3.1, does not say 64 bit which it says for 12.0 and later
Janne
HTML code is On
AAX Plugin loading Black Rooster Audio loonytunesmith AAX Plug-ins 1 02-02-2021 04:43 AM
Black Friday 2018 Plugin Bonanza! JCBigler AAX Plug-ins 117 01-05-2019 03:39 AM
WTB PLugin Alliance HG-2 Black Box $150 bugnut Buy & Sell 0 04-15-2017 05:17 PM
New Free Waves plugin Black Friday nst7 AAX Plug-ins 17 11-29-2014 12:09 PM
