Old 01-15-2016, 05:29 PM
Tonetek Tonetek is offline
Default Eleven Rack Driver Uninstall
I ready to install the eleven rack 1.2.8 driver on El Capitan. However, I am getting the error 5364 when running the Avid Eleven Rack driver uninstaller.
Any ideas?
Old 01-15-2016, 06:41 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: Eleven Rack Drive Uninstall
Welcome to the community.
Are you running the uninstaller included with the new driver?
Old 01-15-2016, 07:55 PM
Yes. I'm using the Avid uninstaller.
Old 01-16-2016, 09:52 AM
Cowboy Bob's Avatar
Cowboy Bob Cowboy Bob is offline
Be sure your 11R is not turned on when you try to uninstall the old driver.
You'll need to restart your computer before you can install the latest driver.
Just FYI
"If the grass looks greener on the other side of the fence, well, it is likely due to the amount of manure being spread on that side of the fence." Cowboy Bob
Squaw Creek Road Studio
Bob
Pro Tools Standard (2021.6)| Pro Tools Carbon | Sibelius Ultimate (current version)
3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Catalina |
Avid Eleven Rack ERXP | Focusrite Clarett 8Pre X | Lenovo i7 ThinkPad | Win 7 Professional | Avid 003 + Rack |
Old 01-16-2016, 12:42 PM
Yes I had the Eleven Rack off and unplugged form the usb port. I ended up manually deleting the digidesigenelevenrack.kext file from the extension folder. I'm not sure if there are other files to delete. I ran the installer and so far so good.
Old 01-16-2016, 05:27 PM
jeffro's Avatar
Default Re: Eleven Rack Driver Uninstall
Glad to hear you are up and running.
I have tried every combo of install/uninstall with 1.2.5 and 1.2.8 on OS X 10.11.2 and could not make it fail. If you run into this again we might want to collect logs and get more info.
Old 01-16-2016, 05:36 PM
One question would be did you do an insitu OS X upgrade with the previous drivers installed? If you did all bets may be off.
Old 01-17-2016, 06:50 AM
Yes, I did upgrade to El Capitan with the old drivers still installed.
El Capitan Eleven Rack Driver is HERE! guitaramundo Eleven Rack 1 01-15-2016 07:28 AM
How Do You Manually Uninstall Eleven Rack JoeGuitarist Eleven Rack 0 12-05-2015 08:15 AM
Eleven Rack Driver for ElCapitan Timothy2009 Eleven Rack 1 12-03-2015 06:55 AM
How to Uninstall Digidesign Eleven Rack from OS Preferences wdjudd macOS 1 08-20-2013 08:18 AM
