Old 09-21-2014, 02:04 AM
jonathancampbell jonathancampbell is offline
Default Midi controller not working after up dating PT11
Hi, please can someone help? Im running PT11 HD native and last week updated PT to 11.2.1. I am running MAC OSX mavericks on version 10.9.2 on an iMac 3.5GHz, i7, 32GB Ram using Raven Mti as a mixer.
After updating PT I have not managed to get my controller keyboard to work. It is a novation 61SL Mkll connected by usb. It worked completely fine before the PT update. Midid through is checked, it is midi input enabled on port 1 and 2 and appears in slot 4 in midi peripherals under HUI port 1 to port 1 (did that itself). I have updated all drivers. If i open a VI I can activate sound by using the mouse but nothing from the keyboard. I have tried recording but nothing. I have tried recording and using the mouse but that also doesn't generate any data in the VI or a midi track either. I have tried unplugging the keyboard and replugging in both with the iMac on and off. I have moved usb ports too and reverted back to where it worked before the update.
I reloaded the auto map from novation to the latest version and it doesn't see pro tools only logic x and live?
I'm tearing my hair out here? I'm guessing I am missing something completely obvious but can't see it? I spent ages trawling the DUC and google to try and fix it but I am now at the point I am completely stuck? Any help will be much appreciated.
Jon
Old 09-21-2014, 02:05 AM
Default Re: Midi controller not working after up dating PT11
PS...it also appears in midi studio and creates a tone under midi test.
Thanks again in advance
Jon
Old 11-07-2014, 12:07 PM
Christian.Focusrite's Avatar
Christian.Focusrite Christian.Focusrite is offline
Focusrite
Hi Jonathancampbell,
Are you on Automap 4.9b2? It adds support for PT 11.
http://beta.novationmusic.com/releases/automap/
PT11 not recognizing MIDI Controller. drumzalicious Pro Tools 11 17 07-19-2016 01:19 PM
midi controller not working? T.Glaze 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-06-2015 02:31 PM
Midi Controller not working davgrn Windows 2 12-01-2013 01:59 PM
Midi Controller not working Precava Pro Tools TDM Systems (Win) 7 12-11-2005 12:01 PM
USB MIDI CONTROLLER NOT WORKING NickFLZ Pro Tools TDM Systems (Mac) 7 07-08-2003 08:48 PM
