"Strip silence" or similar on midi. Is it possible?
The function "Strip silence" as such seams to not work on midi, even in the Clip mode. Is there any non-wanking method to quickly get rid of all the empty parts of the Clip blocks? Of course, it's not the same as with audio, because there is always empty space and silence between midi notes. So I mean mainly/or basically the detecting and then the cleaning of all emptiness before the first note and after the last. (Check the attached pic.) Thanx in advance! Last edited by DigitalVortex; 03-15-2023 at 07:02 AM. |
Re: "Strip silence" or similar on midi. Is it possible?
Just my preference, but for midi, I would simply use the TRIM tool(in GRID mode) to trim the clips for "house cleaning", but I would not dig too deeply as it serves no purpose(to me). The "Strip Silence" function(to me) is about removing low-level noise in audio tracks, and midi/instrument tracks have no noise to worry about. My other preference is to set midi/instrument tracks to show notes(except when I need to copy/paste clips)
Nope :) Not practical.
I think you could take the midi track, convert it to audio. group the two tracks. then use strip silence on the audio track. After getting your settings to where you want them, use the Separate function to just cut your desired clips. then you are able to select the audio bits you "didn't want" (while the tracks are grouped) and it will select the same zone in the midi track and you can hit delete.
Help me out here as I still am unclear on why this is desired(20+ years in and am still learning)
At least for the note onset, not necessarily decay or tail of MIDI instruments (just like reverb or delay between visible audio clips with silence stripped). I wouldn't see a reason for me to do this either. But everyone's workflow is unique. And there could be significant advantages to some work needs. Sent from my Pixel 6 Pro using Tapatalk
___ >> me: nednednerB // ||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music // ||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 // ||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock // ||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR ||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts // |
Difference between "Midi Studio Setup", "Midi Input Devices", and "Midi Controllers"? | GOOOTOOO | Pro Tools 2020 | 5 | 04-01-2020 01:23 PM |
Clicking "Add MP3" adds ~1min of silence to the end of the file | ouchmypockets | Pro Tools 2018 | 3 | 08-16-2019 07:53 PM |
"Digidesign Midi I/О" in "ProTools 10HD" in "OSX Maverics" | electra1006 | MIDI | 0 | 06-18-2018 05:46 AM |
Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List" | EdgarRothermich | Pro Tools 12 | 2 | 10-04-2017 02:18 PM |
Does ProTools have a plugin similar to Audition's "Speech Volume Leveler"? | EricKline | Pro Tools 12 | 8 | 01-11-2017 07:33 AM |
