Old 12-05-2010, 01:05 PM
Bos Def Bos Def is offline
Default Pro Tools 9 and Behringer Mixer
Currently, the home studio setup we use is an old Behringer Eurorack (UB1222FX-PRO) mixer directly into the PC's soundcard. We use Adobe Audition right now but want to upgrade to Pro Tools 9.
Is this mixer compatible with PT9? Also, if you have any suggestions for improvement on our setup I would appreciate that. Keep in mind though that this is barely more than a hobby project we're developing at the moment. We want to keep it relatively inexpensive.
Old 12-05-2010, 02:15 PM
sunburst79 sunburst79 is offline
Default Re: Pro Tools 9 and Behringer Mixer
Does the mixer have ASIO or Core Audio drivers? If so it should work. Check the AIR User Blog where they are compiling a hardware list for the latest information.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 12-05-2010, 04:25 PM
I believe it does have ASIO drivers because I was checking out Behringer's site for info. Here's a link to the page for my mixer. Near the bottom it has ASIO drivers (32-bit, Win 7 would be mine). That's what I'd need?
The AIR User Blog didn't have any Behringers as far as I know, that's why I posted. If it does work, I'll be sure to add to the list.
Thanks sunburst.
Old 12-05-2010, 04:37 PM
Siegfried Meier Siegfried Meier is offline
Isn't this just a fully analog mixer? How can it possibly have ASIO drivers...
Old 12-05-2010, 05:02 PM
Noiselab Noiselab is offline
It's got some DSP implementation on it for the built-in FX, but I don't see any USB/Firewire/AES-EBU or S/PDIF connections on it anywhere. If it has ASIO drivers for it, the only thing left would be Bluetooth or WIFI...
NL
Old 12-05-2010, 05:08 PM
That means new mixer. Whee. Any suggestions for less than $100? Preferably enough inputs for a simple hip-hop vocal tracking session but also enough for a rock group including drums.
Old 12-05-2010, 07:54 PM
getz76 getz76 is offline
All analog gear works with Pro Tools. The thing is, you need a computer audio interface.
It sounds like you have been sending a stereo (2 channel) signal to your computer. You could likely continue to do so without purchasing additional gear.
Less than $100? There's not much available in that price range.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 |
| Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 |
Old 12-06-2010, 05:44 AM
AndyJCP AndyJCP is offline
If you have used your Computer soundcard as Audio Interface before, you can most likely continue to do so with PT9.
You need an ASIO driver for the sound card, but there's a freeware called ASIO4ALL which normally should work.
Cheers,
Andy
Old 12-24-2010, 10:29 PM
If I get an audio interface, what are some of the options, keeping in mind that I need to track drums with at least 4 or 5 mics at a time. Just throwing an audio interface in between the mixer and PC (probably firewire) will work?
Or as AndyJCP posted, if I understood it correctly, I don't need any new hardware. I already use ASIO4ALL for the soundcard.
Thanks for all the help, because honestly I'm more software-oriented than hardware. Really appreciated.
[IMG] code is Off
Pro Tools 10 with Behringer Xenyx Mixer vw45 Pro Tools 10 6 09-28-2016 11:52 AM
M-Box 2 Mini + Behringer 802 Mixer ????? LilDecs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-08-2011 05:39 PM
Alesis 32 mixer and Behringer headphone amp TrippSTRAT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-08-2003 01:01 PM
Anyone using the Behringer MX2442A Mixer??? Big Tyme 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 12-03-2002 12:34 AM
Anybody using the anologue behringer mixer MX3242, WestPhillySoulzition 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-10-2001 08:05 PM
