How to load Mach Five samples into structure
Im wondering if there is a way to load mach 5 samples or other non digi samples into structure? I am able to find them within structure but I want to load them into it just like the structure samples do. Also how do you make the samples so that you can audition them before choosing? I noticed that some samples have a small speaker next to it to audition and some dont. Is there something special I need to do to the samples?
I found that other people have had problems with structure but none have asked about these two issues; any ideas? |
Re: How to load Mach Five samples into structure
Hello,
I also come from a Mach V sampler. I selected all the samples(of one instrument),just drag and dropped but the problem was that the samples looped. Now I convert them first with Toast as aiff and drag the "new" samples into structure. See my thread about it : http://duc.digidesign.com/showthread.php?t=234944 Hopefully it helps a bit. |
I understand what you mean.
I don't have really that much samples, they map when you select all your sample , there's a pop up dialog, but it probably isn't the same mapping as in your Mach V. Can't really help sorry. |
Structure Free unable to load homemade files from Structure 1.0 | tuchel | Virtual Instruments | 0 | 04-26-2013 09:10 AM |
Load sf2 Samples in Structure? | audioplace estudios | Virtual Instruments | 1 | 06-01-2010 07:20 PM |
Structure Free is taking forever to browse & load up samples | QPro5-AM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-02-2010 06:32 AM |
any way to convert Mach 5 library to Structure? | crizdee | Virtual Instruments | 10 | 08-14-2009 08:11 AM |
Structure and Mach 5 | demians | Virtual Instruments | 6 | 08-03-2007 06:16 AM |
