Shortcut help - snap to previous / next?
Hi guys I neep a litle help. Is there a keyboard shortcut for the command "snap to previous / next region". I have searched the manual and the shotcut reference document but with no luck... Thanks in advance Jakob
Did you talk to your talkbox today? |
Re: Shortcut help - snap to previous / next?
cmd+ctrl+grab = snap end of region to cursor
ctrl+grab = snap beginning of region to cursor ctrl+shift+grab = snap sync point to cursor The only "real" snap to previous region would be while editing in shuffle mode. Then, simply drag the region to the left. Unless someone else knows otherwise? Good luck. -Ryan
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Also:
Ctrl & Right Click on region will bring up a menu (as of PT 7.3) with options for snapping the regions start, sync point or end to the cursor. Right Click on region will bring up a menu (as of PT 7.3) with options to snap the start / end to the previous / next region (I seem to remember). I'm also surprised at how few people seem to notice that you can set the grid to "Regions / Markers" (a similar result can be achieved by holding down the Start key - as far as I remember - and dragging it up to the nearest region). Hope that helps. |
Thanks for the answers - I will try it out Jakob
You can set your own keyboard shortcut in OSX for Snap to.... in conjunction with cntrl/cmd -l/' that speeds up the procedure quite a bit.
I'm using Keyboard Maestro with a script however (like Autohotkey but for OSX). You can record "do as I do" scripts really easily, or simple write your own shell script if you're so inclined. |
Snap To Next/Previous QuikCommand? | ccanigs2 | Tips & Tricks | 6 | 09-21-2013 03:15 AM |
Keyboard Shortcut Request: Snap to Previous / Next | neotone1 | Pro Tools 9 | 1 | 12-02-2010 08:07 AM |
Key Command: Snap Region To Previous? | Sonic Nomad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-31-2010 02:53 PM |
PT7.3 - snap to next / previous key command? | Mark Dann | Pro Tools TDM Systems (Mac) | 3 | 10-24-2007 04:22 AM |
Previous/Next Shortcut for Expand??? | John Pisciotta | Virtual Instruments | 0 | 06-13-2006 08:37 AM |
