using Mojo as DV firewire/analog converter
I'm using an LE + Digi 002 system. Some video jobs are also done on the same G5 with Mojo. I'm currently using a Canon XL1 DV cam for outputting DV video tracks to TV displays. Is it possible to use Mojo like a DV to analog converter instead of Canon. Another question: I'm using 18 qt frames sync offset to compensate DV-Analog conversion. It says in this post that Cinema display has 1/2 frames of latency. Then I need to use a 4 qt frames of latency when using only the Cinema Disp. , right? Thank you all (Sorry if I'm bringing up a previously discussed thread) G5 Dual 1.8 2 GB RAM Digi 002 + PT 6.7 LE Avid Mojo Apple Cinema Display 20"
HD3 + Control 24 + 2 192s Mac Pro 12 core 2.93 & PT 8 16 Gig RAM Glyph Firewires Motu MTP AV USB |
Re: using Mojo as DV firewire/analog converter
I have a similar setup in that I'd like to monitor the video track on a seperate monitor via the MOJO.
Currently running 6.9.2 LE with DV Toolkit & Digitranslator 2.0. Jon Pomplin Mac G5 1.6 002R (on Adaptec 8300 Firware card) PT 6.9.2 DV ToolKit Avid Mojo (on Mac Firewire bus) Avid Xpress Pro 4.8.2 |
analog to spdif converter | legacygt777 | General Discussion | 10 | 07-14-2013 08:35 PM |
Analog Mojo with new 8 core Mac Pro's | rafukyo | Pro Tools TDM Systems (Mac) | 4 | 08-28-2008 02:26 PM |
would i need a analog to digital converter | vdz415 | ICON & C|24 | 1 | 02-12-2007 01:43 AM |
using Mojo as DV firewire/analog converter | Impala | Post - Surround - Video | 1 | 01-28-2006 06:21 AM |
Analog to lightpipe converter | Steve2000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-10-2003 06:48 AM |
