![]() Quote:
![]() Why wouldn't it? In fact, back in the day I actually did a comparison between 002R@96k and Digi96@48k and found that there is very little difference, if any. And the 003 is a direct successor to the 002, most improvements not affecting the sound.
LOL, that would be too easy. Although, it would make it harder to 1/2 jack the sleeve to get around a mixer with no direct outs.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
Thanks all. I've decided on recording at 48 kHz and will pickup an ADA 8200. I'll have 12 pres and 4 lines and I'll use the Mackies 1604 mixer which has 8 line outs post eq. I'll take another 4 signals from half jacking insert line outs. I'll probably use the remaining 4 line inputs for taking an RCA left and right tape out run through a Di to balance the signal.
Any assistance is greatly appreciated, Thunderbird. ![]() |
![]() Quote:
Or if you want something a bit more clean looking, that you can keep in your rack and not have any cables in the front fighting with any of the knobs (a la ada 8200) if you have big fingers like me, you can go with the octopre mk2 dynamics, it's about 100$ more than the mk2 but all the inputs are on the back side, which I find is a lot more visually appealing and helps to keep things clean in the studio or on a live rig. |
#16
+1 for octopre. the old ones sound even better, if you can find one cheap with AD card. the mk2 versions though have the digital option built-in so it's safe choice if you need that digital.
#17
I'll keep an eye out for an octo pre but new there 900 bucks here so it's a rort. I can't buy from the US as I need 240 volt and a converter is just too much gear.
#18
How about www.ebay.co.uk then? That's 240V gear like everywhere else in EU.
I found this one in a minute. Though the user has not specified anything other than shipping to UK in my experience (generally speaking) EU sellers usually don't have a problem shipping internationally.
#19
I'll check it out. Thanks.
#20
Just found one locally as new 450. Bargain.
Not enough ASIO output channels available.at least 2 channels are needed. | kudca | Getting Started | 1 | 05-26-2013 05:05 PM |
Recording Only On 2 Channels | blindside777 | Pro Tools M-Powered (Mac) | 0 | 01-10-2012 02:12 PM |
clicks in recording on all channels | JeffGT | Pro Tools M-Powered (Win) | 3 | 02-16-2008 03:29 AM |
recording 8 channels at once? | seneros | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-10-2006 11:53 PM |
Recording on all eight channels on DIGI 002 | calibos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-22-2006 10:28 PM |
