Old 09-20-2006, 06:51 PM
calibos calibos is offline
Default Recording on all eight channels on DIGI 002
I am recording with MBOX2 but I borrowed an 002 rack to record drums. I am planning to record drums on all eight channels (4 Xlr and 4 1/4") at the same time. Any suggestions on this method?
Also, just as a test I put a mic 1/4" cable in on channel 1 with an xlr already going into channel 1 and got a clear signal on both mics. I have yet to check but will there be any sound seperation between the to mics going in. Is this completely wrong and unnecessary?
Old 09-20-2006, 08:01 PM
randyT randyT is offline
Default Re: Recording on all eight channels on DIGI 002
calibos,
On the 002R the first four inputs have mic pre-amps and the last four inputs do not. There is a switch on the front panel that switches the first four inputs between mic (XLR input) and Line/Inst which is the 1/4" jack. Only one or the other is active depending on the front panel switch position. You are going to need four more pre-amps to use on inputs 5 - 8 since they do not have built in mic pres.
randy
Old 09-21-2006, 05:28 PM
Randy,
Thanks. So you are saying that I need a pre amp to use 5-8 no matter what? Can i use a mixer as a preamp and run 1/4" cables out of the mixer into channels 5-8?
Old 09-21-2006, 07:33 PM
yes...definately. A mixer is a good way to go.
randy
Old 09-22-2006, 10:28 PM
Thanks. Big help.
Recording Only On 2 Channels blindside777 Pro Tools M-Powered (Mac) 0 01-10-2012 02:12 PM
clicks in recording on all channels JeffGT Pro Tools M-Powered (Win) 3 02-16-2008 03:29 AM
recording 8 channels at once? seneros 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-10-2006 11:53 PM
recording 18 channels with 002 at the same time BrianH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-30-2006 05:17 PM
Recording more than 8 simultaneous channels? scottyplayero 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-29-2003 04:16 PM
