Old 04-17-2012, 05:59 PM
yanos yanos is offline
Default Clip Gain rendered with Audiosuite
When I render a clip with an Audiosuite plugin, the clip gain automation volume is rendered at the same time.
Is it possible to disable it ?
Old 04-17-2012, 06:52 PM
DJ Hellfire DJ Hellfire is offline
Default Re: Clip Gain rendered with Audiosuite
Doubt it! Although I don't really see this as a problem since you can just re-adjust the clip gain as needed!
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 04-17-2012, 08:36 PM
Yeah, its a work flow thing and sometimes new features require us users to alter our habits a bit. Better to do other editing first and leave clip gain for the start of your mixing phase(but as said, you can re-do or change it at any time as fast as you did it the first time around).
Old 04-18-2012, 04:11 AM
Ok thanks.
Of course I can redo the volume automation. But I think it's useless to render that precisly because there is now clip gain. It could be better to keep the whole volume of a clip with a plugin rendered.
Anyway I have to alter my habits or readjust the clip gain after.
Old 04-18-2012, 10:00 AM
The actual gain of the clip is still the same, technically (not counting how the audiosuite processing may have altered it, depending on what plugin you used). It's just the line get's reset back to 0! I don't think there's really anything you need to "alter" as far as your habits go. And there's no need to readjust it unless you actually need the clip louder or quieter.
Pro Tools 2021.12
Old 04-18-2012, 02:00 PM
Dizzi45Z Dizzi45Z is offline
I agree with Yanos. It should be an option.
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 04-18-2012, 05:56 PM
Not really. For example a clipgain at -∞ became a clip without sound.
But the line is not alway flat... Sometimes I make volume automation inside the clip.
It's just a question of habits, but that would be better as an option.
Old 04-18-2012, 07:51 PM
Well of course. That's basically deleting the sound/clip, and that's not a likely scenario either. When clip gain get's rendered, even if you have random humps and lines all over the place, the results should be the same as if you bounced that audio clip to a new audio track via bus or to disk. If the actual volume of your clip is changing just from clip gain being rendered, then it sounds like you have some other issue going on! As long as you don't push the clip gain up to clipping or set it to -∞ before rendering (which no one with any sense would do), the gain can be completely restored to any volume you want!
But I guess your option request could be useful if you wish to later retweak certain clip gain points without having to recreate them. So what I would suggest is before you render any clips, copy the clip gain first, render, then paste the clip gain back onto the clip. Or duplicate the clip, render the original, then copy the clip gain from the dupe back to the original. Should work fine!
Pro Tools 2021.12
Old 04-19-2012, 01:25 AM
tj_davies tj_davies is offline
I think there is a differing approach in how others use clip gain. I use it to even out volume, for example when music is too low at some point in the mix or a vocal take has too much dynamics. So basically evening out the levels before they go into the processors-
Mixing wise I still use volume automation.
To sum it up I use clip gain before I mix.
In my case, audiosuite rendering the clip gain doesn't annoy me, as the the clip gain is more a volume repairing tool than anything else.
For others, if they use clip gain to mix, then I understand why rendering could become annoying. But I actually doubt that clip gain was introduced as a mixing tool.
Just my 2 cents,
Timothy
Mac Studio Ventura 13.6
PT 2020.12.0
www.pearls-music.com
Old 04-19-2012, 02:54 AM
Cryos's Avatar
Cryos Cryos is offline
Smile Re: Clip Gain rendered with Audiosuite
Slightly off topic, but is there a way to render clip gain with handles?
So far I haven't been able to do this, am I missing something?
Cory Rizos, CAS
Re-recording Mixer/Sound Designer
Montreal, Quebec
http://www.imdb.com/name/nm0007185/
coryrizos.com
AudioSuite Gain/Normalize also on Clip Gain A-n-d-i macOS 0 03-13-2014 01:46 PM
Audiosuite & Clip Gain - BUG??? fm_xtk Pro Tools 10 4 01-27-2014 03:06 AM
Wacky!? Audiosuite rendered files missing after backup barneykeys Pro Tools 9 0 07-27-2013 09:51 AM
Clip gain on clip groups: bug or feature? idris Post - Surround - Video 6 01-02-2013 11:48 PM
Audiosuite render causes Bus thread error on clips with 'Bypased clip gain' asparknz Pro Tools HDX & HD Native Systems (Mac) 0 08-19-2012 05:04 PM
