Old 12-07-2007, 02:08 PM
Cal_MArtinez Cal_MArtinez is offline
Default the \"Toggle Mix and Edit windows\" shortcut won\'t work.
I've just bought an Mbox2 along with a brand new MacBook Pro 2.2Ghz, 2Gb ram and an 500Gb external harddrive. I'm quite new to OS X but it kicks ass compared to windows! Now, the only problem i had so far is that i can't get the shortcut "control+equal" (Toggle Mix and Edit windows) to work! Does anyone have a sugestion how to solve this?
Peace
Cal.
Old 12-07-2007, 02:16 PM
Default Re: the \"Toggle Mix and Edit windows\" shortcut won\'t work.
On a Mac the Apple key is used where on XP you used Control.
Option = Alt
Control = Start (Win)
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 12-09-2007, 02:12 AM
Holly73 Holly73 is offline
Don't know the Danish keyboard layout, but maybe you also need to add another key to this shortcut.
Ok, I found out, yours is similar to the German one.
So, you need Cmd + Shift + 0, as Shift and 0 equal =.
Or you use the = from the numlock section. Then it is Cmd + Fn and the the key labeled with =
If you work with the English layout, just do, what Rail suggested above.
Did this help?
 MBPr 15" (Mid 2015) i7, PT12.4, Studio One 3, UA Apollo Quad Firewire
Old 12-09-2007, 08:57 AM
Starcrash Starcrash is offline
As with most OS X applications, Cmd+` (the little accent guy at the top left of the U.S. keyboard) toggles through open windows in Pro Tools. I find this to be the most convenient way to toggle back and forth between Edit and Mix windows. Just make sure both are open. If either of the Digibase windows are open, they too will be included which is pretty handy.
Pascal Garneau | IMDb
Old 12-16-2007, 10:47 AM
Thanks a lot guys! pressing "Control (apple button) + shift + 0" worked. (The shift part did the trick;-)
For the first time in 4 years everything just works with my Pro Tools setup. No errors, just pure creativity! Switching to Mac is by far the best thing i've done so far...
Peace.
Cal.
Toggle Mix and Edit windows michaelm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 06-15-2010 07:49 PM
toggle mix and edit window shortcut daven 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-02-2005 02:02 PM
toggle view keyboard shortcut doesn't work Saar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-10-2003 08:54 AM
Help me toggle the view with a shortcut Saar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-09-2003 06:47 AM
track view toggle keyboard shortcut won't work!! Saar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-16-2003 06:51 AM
