Old 09-19-2007, 07:15 PM
MixerGuy MixerGuy is offline
Default ProTools messing up audio when importing video
I’m experiencing an odd issue that I haven’t seen before...
I have a 45 minute .dv file (that has correct, in sync audio in it) at 48k 29.97 - when i play the quicktime using quicktime player, it is fine - (I created the .dv file myself from a .mov - set to NTSC 48k - keep audio locked - all the usual settings - and when I play the .dv all is good...)
I create a new session on my video playback rig (ProTools LE 7.3.1 cs4 with DV toolkit 2 - at 48k 29.97fps - set to internal clock - with a 002rack) - and I set the session start time, then import this video file, and tell it to place the video at session start time, and import the audio.
I’ve tried this 4 times now.... when it has finished, the audio is all garbled, as if it is playing back too fast.... and it is all out of sync - significantly.
any ideas?
Yes - I trashed preferences, and restarted.... and tried a fresh session - twice... no luck.
This is really odd.
thanks
Old 09-19-2007, 10:41 PM
Default Re: ProTools messing up audio when importing video
anyone?
i suspect it might be a cs4 issue - ?
7.3.1. cs4 LE on a G5 PPC dual 2.7 - 10.4.9
Old 09-19-2007, 11:48 PM
SwirlyD SwirlyD is offline
I had this last week and found I needed to export the audio to an AIFF in Quicktime, then import it into the session and it was fine....I was working in PAL 25fps on an HD system. Sometimes I don't have the problem, so I suspect it's something to do with certain types of QT files and how they were created.
Old 09-19-2007, 11:58 PM
so..... ok it seems to be cs4 - but only PPC - not Intel
i just did it on my Mac Pro - exact same .dv file - and it worked perfectly....
but on my g5 - no good.
so a bug in PPC 7.3.1 cs4 - LE
hello Digi!?
Old 09-20-2007, 12:09 AM
I had this last week and found I needed to export the audio to an AIFF in Quicktime, then import it into the session and it was fine...........
great idea - thanks!!!!
HTML code is On
Delay Compensation Messing Up Video Sync..? Jon_Atkinson Post - Surround - Video 21 06-07-2015 08:46 AM
Protools 8.04 Crashing when importing video (.mov) files guileman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 10-28-2010 01:48 AM
Importing Video Into Protools 7.3.1 KMAN385 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-25-2008 07:08 PM
QT Video messing with my 7.3 LE PC set-up a little. s0und80y Post - Surround - Video 1 06-11-2007 01:04 AM
Importing video into a PC: audio messed up j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-24-2002 09:41 AM
