Old 12-24-2002, 04:04 PM
Jim Borchardt Jim Borchardt is offline
Default Firewire drives instead of scsi?
I finally made the jump to a Mac G4 dual 1 gig. My old Windows NT system is now used for playing Asteroids. The Adeptec 19160 SCSI card that ran in NT is not compatible in Mac, although I could still use the two Seagate Cheetah drives as my "audio files only" drives like I did with NT. Here's my question. Do I need to invest in a Mac (and PT) compatible SCSI card, or can I use one or two external Firewire drives for audio files during recording. I'm not familiar with Firewires transfer rates or other specifics for this application. I'm running PT Mix/24, and PT v5.1.3. Thanks for any advise.
Old 12-24-2002, 04:36 PM
Bookerv12 Bookerv12 is offline
Default Re: Firewire drives instead of scsi?
I have an HD 2 system now,,,
I have 4 Firewire drives that I use instead of my scsi stuff now.
I still have the scsi drives, but don't really ever use them anymore.
As a matter of fact, I only use two of the Firewire drives for audio.
I have been running fairly large mixes off the firewire drives (36 tracks plus) and they work great.
There is a slight speed difference, (Record start, etc) but it works great.
I know that they will be coming out with Firewire 2 in the near future, and that will probably be the end of scsi.
I say go for the Firewire drives.
Good luck.
bookerv12
Old 12-24-2002, 05:28 PM
jho jho is offline
Firewire!
I have 3 firewires on HD and run 60-80 tracks all day at 48 with no lag.
Much cheaper and you can build your own. Ebay has IDE/ATA 7200 RPM 80G drives for 75 bucks and www.granitedigital.com has the bridgeboards. I even have a removable firewire granite digital tray for my backup and as I fill up drives I start on a new one.
Yeah scsi has the best performance but for most applications firewire is perfect, much more affordable and easier to come by.
J.Ho
Old 12-24-2002, 05:31 PM
maxserg maxserg is offline
I second all of theese posts! [img]images/icons/wink.gif[/img]
Old 12-24-2002, 06:34 PM
audiobob's Avatar
audiobob audiobob is offline
YES! Have an 80 gig OWC Mercury Elite that has never skipped a beat. Am now SCSI-less and loving it.
Old 12-25-2002, 07:32 AM
tal herzberg tal herzberg is offline
Just switched to 2 Glyph hotswap FireWire bays, running 64 trx of 96Khz audio using 2 drives, no problems at all.
Old 12-25-2002, 11:42 AM
Thanks for all the advise guys, (and girls?). It's what I was hoping to hear. Happy Holidays everyone!!
Old 12-25-2002, 02:51 PM
PMoshay PMoshay is offline
Firewire kicks butt!
The only thing to watch out for is...firewire bridgeboards ocassionally go bad (ive had 2 go bad), and they will take your data down with them sometimes (50/50 chance).
Ultra SCSI definately responds faster, but it can be negligable sometimes, and mabe not worth the convience and savings of firewire.
i've found Cobra firewire drives w/ibm drives to be the fastest of my drives (i have about 6 different types).
Vive la Firewire!!!!!!
www.LiveFromDarylsHouse.com
Old 12-25-2002, 08:24 PM
lancejorton lancejorton is offline
firewire can conceptually never be as fast as SCSI... why? because firewire is basically just external EIDE, and the controller is not as fast. there will always be room for SCSI in high-end pro audio. SCSI can read & write at the same time, something the IDE controller is just not designed to do. however, if it works, it works and i'm glad to see an alternative solution that will hopefully bring down SCSI prices.
lance
Old 12-25-2002, 08:33 PM
MARVINBASS's Avatar
MARVINBASS MARVINBASS is offline
I've been using firewire drives for 2 years now and never looked back. I'll only use Glyph drives, cause they rock!
My System is:
Mac Pro 3.2GHz 6 Core
32GB RAM
1- HDX
1 - Apogee Symphony Mk2 8x8
1 - HD 16x16 Interface
MOTU MTP/AV
Second System
Mac Pro 2013 3.5GHz 6-core Xeon E5-1650v2
32GB RAM
1 - HDX
1 - Avid Thunderbolt 3 Expansion Chassis
1 - HD 8X8 Interface
MARVINBASS Digital Audio, LLC
Ex PT Beta Tester
Woodland Hills, CA.
Firewire or SCSI drives anders Post - Surround - Video 7 08-09-2005 10:06 PM
SCSI and FIREWIRE drives are cheap now. el matador 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-15-2002 02:45 AM
ANDRE & TOM: Adaptec cards to copy from SCSI drives to Firewire drives with G4/HD? ragbor Pro Tools TDM Systems (Mac) 8 06-11-2002 08:08 AM
Differences between using SCSI drives and Firewire drives ? pepasmax Pro Tools TDM Systems (Mac) 0 05-28-2002 01:28 PM
FIREWIRE DRIVES X SCSI DRIVES Alécio Costa Pro Tools TDM Systems (Mac) 5 02-04-2002 07:27 AM
