Old 07-12-2007, 04:56 AM
Ortli Ortli is offline
Default mbox - all LEDs (except peak, 48V & USB) on, not recognized
Hello,
I'm using the old mbox on my PowerMac Dual G5 (2 GHz). I've just borrowed the mbox from a friend and plugged it in 2 days ago. I downloaded and installed the standalone driver from digidesing.com since I'm using Logic. It worked fine.
When I started my Mac today, all LEDs except 48V (which isn't turned on), USB and the peak lights went on and the mbox isn't recognized anymore. I plugged it out and in again a few times, always the same, all LEDs are on, no matter how often I press the source button on the mbox. I also restarted the Mac a few times, nothing changes. When I press the 48V button, the 48V LED appears (at least...).
I don't know what to do! Is the mbox broken? Does anyone know how to make it work again?
Thank you in advance,
Ortli
Old 08-15-2007, 09:07 AM
kisko pascual kisko pascual is offline
Default Re: mbox - all LEDs (except peak, 48V & USB) on, not recognized
I have the same FU%***G problem!!!! Nobody knows any solution!!!Can you help me please !!!
Thanks!
Old 08-15-2007, 10:51 AM
DigiTechSupt's Avatar
You should try installing the latest v22 firmware available on this page:
http://digidesign.com/index.cfm?navi...&categoryid=36
If it's corrupted firmware, that should fix it. If it doesn't help, it's very likely the Mbox is defective and in need of repair. You can call tech support by phone for information on geting it fixed.
Avid Audio Tech Support
Support FAQ
Control 24: Preamps not working and Peak leds are lit at all times andreconde ICON & C|24 2 11-07-2014 03:37 PM
Avid Mbox flashing leds ym2149 General Discussion 2 04-02-2012 12:54 AM
Mbox 2 flashing Leds Luca Silipo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-01-2007 01:42 AM
Mbox 2 Flashing Leds Luca Silipo Pro Tools TDM Systems (Mac) 2 12-31-2006 03:07 PM
Mbox Peak / Peak Light Issue soulcatcher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-29-2004 08:01 PM
