Old 10-26-2003, 02:33 AM
Bluetide Bluetide is offline
Default Sample / Bit Rate Conversion ?
Just wanted to get an idea for the smartest / easiest way to convert some sessions from 44.1 / 24 to 48 / 24. I created a template @ 44.1 / 24 quite awhile ago, and have been using that for all new sessions. I started to do some scratch tracks for about 5 songs (5 different sessions) w/ the 44.1 / 24 bit template, and before I start to record the drums, etc..I want to bump everything up to 48 / 24. Would it be easiest to just bounce the individual tracks in each session (there's about 4 scratch tracks per session), and convert to 48 in the process?, OR another option I was thinking of is to use, "import track". Will that allow me to convert as I'm importing? I figure I'd post this, so when I'm back in front of my PT computer I'd have a little more assurance as to what direction to go with. Any thoughts would be much appreciated.
Old 10-26-2003, 06:59 AM
mindnoise mindnoise is offline
Default Re: Sample / Bit Rate Conversion ?
you can do either, though importing can be a bit faster,just make sure to have "tweakhead" selected in the conversion qualitiy prefs, to get the least resampling/quantification loss.
best
last: PT11.3.1
Old 10-26-2003, 11:10 AM
Thanks for the reply mindnoise. Will Do.
Sample rate conversion? meathman Pro Tools TDM Systems (Mac) 10 05-19-2007 05:09 AM
sample rate conversion stickytapenrust Pro Tools TDM Systems (Mac) 1 04-25-2005 04:24 PM
sample rate conversion stickytapenrust 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-25-2005 02:20 PM
sample rate conversion D Clarkson Tips & Tricks 13 04-15-2003 10:38 AM
Sample Rate Conversion ThreeBlake 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-08-2002 12:55 AM
