Old 05-15-2007, 08:01 PM
meathman meathman is offline
Default Sample rate conversion?
I have an audio file at 44.1, but my session is at 48k. If I import the 44.1 audiofile into my 48k session, the track is higher in pitch.
I need to find a way IN por tools to convert this file, import audio does not give me this option. Must I convert BEFORE is import into pro tools or can I convert the file another easier way WITHIN protools without having to do anything like save copy in etc....
Thanks
Old 05-15-2007, 10:46 PM
boneboy boneboy is offline
Default Re: Sample rate conversion?
I use:
http://www.audioease.com/Pages/Barba...rbaBatch4.html
It is amazing. Keeps all the folders in tack as well. Highly recommended
Old 05-16-2007, 12:52 AM
narcoboy narcoboy is offline
Im pretty sure the SRC is done on import - i'll check later and get back..
Old 05-16-2007, 01:14 AM
tj_davies tj_davies is offline
Pro Tools for sure can do the sample rate conversion on import.
What Pro Tools version are you using? Are you sure your clocking is correct?
Hope this helps.
Timothy
G5 10.13.6
PT Ultimate 2019.12.0
www.pearls-music.com
Old 05-16-2007, 04:18 AM
crizdee's Avatar
crizdee crizdee is offline
Hope this helps.
Timothy
He needs to sample rate convert and change the speed back to that of the orignal 48k session! (yes it looks like he had a clocking problem when this file was recorded!) simply importing back into PT will not adjust the speed!!
He does indeed need barbabatch or similar! or record the file onto a second recording device via analogue i/o then import it back into PT at 48k
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-16-2007, 04:26 AM
If that's the case, Chris, you're right!
Either Barbabatch, or recording the file analog at the wrong clocking and then recording it back at the right clocking.
Timothy
G5 10.13.6
Old 05-16-2007, 12:27 PM
Borg Borg is offline
I'm fairly certain that you can use the "Import Session" dialog box to fix the problem. There is the Apply SRC option, which one checked, allows you to tell Pro Tools what the source file sample rate is. If the file was improperly tagged at a different speed, you can basically "lie" to PT and tell it a different sample rate. Post guys use this all time to back out of problem situations.
- Borg
www.foxmountain.com
@FoxMtnStudio
Old 05-17-2007, 12:44 AM
well, all he says is he has a 48 session and wants to import a 44.1 file. No muck ups, he just wants to import a file thats a different sample rate. SRC will deal with it. He says that the file plays faster - because hes not applying SRC. Not that it was wrong in the first place.
Old 05-17-2007, 01:35 AM
garret garret is offline
But PT automatically sample rate converts the file on import unless you just add it. So if he converted it on import but its the wrong pitch then it points to a previous clocking problem. He should confirm whether he added or converted the file on import.
Garret
IMDB
Old 05-17-2007, 06:56 AM
Garret
bing bing bing!
www.foxmountain.com
@FoxMtnStudio
sample rate conversion stickytapenrust Pro Tools TDM Systems (Mac) 1 04-25-2005 04:24 PM
sample rate conversion stickytapenrust 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-25-2005 02:20 PM
sample rate conversion D Clarkson Tips & Tricks 13 04-15-2003 10:38 AM
Sample Rate Conversion ThreeBlake 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-08-2002 12:55 AM
sample rate conversion dj buttnaked 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-06-2002 03:17 PM
