Old 10-27-2022, 01:12 PM
GCGPT GCGPT is offline
Default Guitar Rig 6 And Pro tools Intro
I'm new on this forum and I'm happy to be here!!!
I have a problem:
I can't see My guitar Rig 6 in the Instruments or effect plug in.
I can see Kontakt and Kontakt 7, Reactor and so on but no guitar rig.
Can you help me?
Thanks!
Old 11-01-2022, 10:25 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Guitar Rig 6 And Pro tools Intro
Hi, Did you check to see if it's listed under another plugin category such as Harmonic?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 11-02-2022, 06:13 AM
thank you cwsaunds
I look every folder of plug in also Harmonics is not everywhere.
Old 11-02-2022, 07:03 AM
junkgear's Avatar
junkgear junkgear is offline
Try running the GR6 installer again and make sure the option to install the AAX plugin is marked to install (should not have a red x next to it).
Will
System Details
Old 11-02-2022, 07:14 AM
thank you junkgear,
before to tray to instal again Guitar Rig,
do you know it this plug in is compatible with protools?
Thank again!
Old 11-02-2022, 12:49 PM
junkgear's Avatar
Originally Posted by GCGPT View Post
thank you junkgear,
Thank again!
Yes, if you are running Pro Tools Intro, then Guitar Rig 6 is compatible. Again, I'm not sure how it was installed on your system, but Pro Tools uses a plug-in format called AAX. Make sure you choose the option to install the AAX version.
If it still does not show up, post back and we can take next steps.
Will
System Details
Old 11-02-2022, 01:48 PM
Then after you have installed it again.
Basic troubleshooting:
Did the installer work correctly? ... is the Guitar Rig 6 .aaxplugin file installed in the plugin folder? /Library/Application\ Support/Avid/Audio/Plug-Ins. No idea what it's called, you can work that out yourself.
Trash prefs. Use Pete Gates PT Prefs utility to make that easy. http://petegates.com/pg-pt-prefs.html
Trashing prefs removes the Pro Tools plugin cache/index (which can get corrupted and cause loading/startup issues but normally you get error messages). So the first time you next start Pro Tools plugins will load more slowly in the splash/startup screen. Make sure you see the Guitar Rig 6 plugin loading. Do you?
Now does the plugin show up in Pro Tools inserts? If not you are likely looking in the wrong place/section. I would expect the plugin to show up under harmonics. But see Preferences>Display Organize plugin by manufacturer... do that any time you are lost/can't find plugins.
Old 11-05-2022, 03:12 PM
Thank you very much a new install of guitar rig 6 solve the problem.
Meny thanks!!!
No input received in Pro Tools Intro Manaberry macOS 7 01-09-2024 09:43 AM
Pro Tools Intro (free) noiseboyuk Pro Tools 37 12-21-2022 10:57 AM
Not A Good PT8 Intro... papasight 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 05-09-2010 10:27 AM
How to add an intro? Sonic Blue Meanie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-12-2010 07:40 AM
Intro and some trouble PT_n00b Pro Tools M-Powered (Win) 5 01-30-2009 05:49 PM
