Programming "enter main counter" key in Eucon
Hi - been trying to program an "enter main counter" key (what the numpad '=' key does) in Eucon. Entering a numpad = in the keystroke editor creates a key that doesn't do anything (I'm assuming because numpad keys aren't recognized as such by the programming software), and from what I can tell, this is not a Euconized command. Doing some digging I found that entering the keystrokes "\p*" works, but my question is why? Is the "\" like the shell/unix escape character and "\p" says following keystroke is from the numpad? There's a handful of these "\" modified keystrokes in the pre-programmed softkeys; are they documented somewhere?
Thanks for any insight! rich
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Re: Programming "enter main counter" key in Eucon
Hey Rich
In EuControl when you're in the Soft Key Command Editor and you add a new command "Key" if you open the drop down list for "Insert Special" you'll see the numeric keypad commands and you can select what you want. see the pic |
Oh yeah! Thanks for that - so I don't see those listed in any of the Eucon programming docs, but at least I can find them this way. Would be nice if these were listed somewhere where they'd be searchable. Thanks!
Hadn't had to program any softkeys in a while but needed to for a client's rig the other day - I'd forgotten how incredibly clunky the whole programming interface is, and it hasn't really improved in the last couple years... This could *really* use some attention!
I think that’s something that has been requested before. You do know you can save and load your personal soft keys on any system? Last edited by its2loud; 10-16-2022 at 08:54 AM. |
yes
"Segmentation Fault" "Main Thread" Error | IceLitch | macOS | 6 | 08-12-2011 12:14 PM |
"Bus error" in "Main Thread", at address 0x0 | qbert1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-28-2011 08:45 AM |
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... | tohmit | macOS | 5 | 03-23-2011 12:13 PM |
Enter the "Activation Code" online fail | Butzenjay85 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-13-2009 01:09 PM |
Main counter mode not switching using "counter" switch | bashville | ICON & C|24 | 2 | 08-07-2009 04:07 PM |
