#21
I think you have it, but in case you did not:
For you to use the INSERT feature in your Input / Output setup, you HAVE to have matching hardware assignments. For example, use 7+8 in AND out for your SPX990. I have been using inserts in most PT versions since they implemented it way back. It has always been the case that you have to use matching IO channel numbers for it to work properly. I'd wire the SPX to 7+8, both the input and the output to it. Keep the Insert label for 7+8 in your set up. Change the label from your Input from 5+6 to 7+8. That should get you signal out and back in. |
#22
![]() Quote:
But his PT I/O assignments should be Input 5-6 and Output 7-8 for his (at least I think that is what needs to happen) That is the relative positioning that Presonus Forum poster is showing as working And yes the difference between the "other posters" screen shots between his Input page and Output pt matrix pages do not make sense to me either BUT I am guessing it is the Quantum PT driver setup that is causing the numerical offset problem and is by default showing the difference and the blank 9-10 on the Output page Given that both the other forum poster and the OP's screen shots, are showing the exact same thing ?? Now obviously I don't have that issue with Avid Carbon (and I am guessing any Avid interface) I simply have my two stereo HW units assigned to 5-6 and 7-8 ,,, Ins and Outs the same PT I/O channel numbers
System : Avid Carbon interface , PT Ultimate 2022.10 .....Mid 2020 iMac 27" 3.8GHz 8-core i7 10th Gen processor,,128GB 2666MHz DDR4 memory,,2TB SSD storage,,Radeon Pro 5700 XT with 16GB of GDDR6 memory,, on Monterey 12.5.1 "Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein Enjoy the Journey.... Kev... Last edited by K Roche; 08-03-2022 at 07:37 AM. |
#23
I have this working now!
![]() Thanks to everyone who posted offering advice. I’ll post my IO settings later tonight when I’m in front of my PC. I basically started again, making absolutely sure PT was using the same Number IO regardless of what it said on the left hand panel. I disabled LLM as suggested by Darryl. I took the outputs and inputs from the Quantum and used a patch bay and connected it up double checking everything I was doing. Boom it worked! Thanks so much ![]()
Tech:Quantum and ASP880 / Yamaha MT120S ![]() Mic Pre's Focusrite ISA One/ DAV Electronics BG1/ Joe Meek VC3 Guitars and Instrumentation:Gibson Les Paul Zebrawood/Fender USA Telecaster/Fender Deluxe Strat/ Martin OM-18V/ Martin D15-M/Gibson SG Bass/ 1972 fender Musicmaster Bass/ 1972 Hayman Drums /Vox,Fender Amps/Roland F130R |
#24
Edit:
I Used the S1 ping test to get the hardware latency value and inputted this into the HW insert delay... 153 samples / 48 =3.18ms Routed the signal to another track and checked the transients all lined up! Looks like I'm in business!
#25
Great it all worked out!!!
Mac Mini M1 | Mac OS 12.6.1 Monterey | Motu 16A | Motu 828ES | Motu 1248 | Pro Tools Studio 2022.10 |
clip gain "wave" symbol. what is it? pics inside | musicmixer04 | Pro Tools 12 | 2 | 09-16-2017 04:40 PM |
How to Insert Pics into Your Post | Barry Johns | General Discussion | 6 | 01-26-2015 11:31 AM |
Should I get rid of my SE Reflexion Filter? Booth plan PICS inside! | DJ Hellfire | Tips & Tricks | 11 | 01-04-2011 09:06 PM |
$1000 i7 920 build complete and successful. PICS inside. | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 04-16-2010 01:21 AM |
Can't hear midi playback inside PT 6.4 | Ditherman23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 08-22-2005 11:48 AM |
