Is there a way to turn off the playback of mute automation, yet leaving on the other automation like volume and pan?
Pro Tools does an annoying thing. When I import tracks from another session, it defaults to importing mute automation, and will write mute nodes on every region on the import even if none were written in the source session. So often I forget to uncheck the "import mutes" when importing tracks. Sp I find myself always having to delete mute nodes on entire tracks manually because I don't see a way of disabling the playback of mutes without affecting other things I do want to play back like volume & pan. |
I'm actually having the same issue. I would really love some input from one of the more knowledgeable guys here!
This isn't the most efficient fix, but have you tried selecting all the problematic tracks in your session, switching them over to show the "Mute" playlist, then selecting all and deleting automation?
Another way is to simply highlight everything in your session, then go to "Edit" and selecting "Clear All Automation" - this will remove any other automation in your session as well so be mindful of that.
Kyle Whittaker www.strangepumpkin.ca Mac Pro (2013) 3.5GHz 6-Core Intel Xeon E5 32 GB Memory OS X 10.12.6 PT 2018.1 |
Switch to Mute Playlist and then hold down Control+command while clicking on the word Mute will make the mute automation inactive.
![]() Quote:
And to add to this, if you hold <Option Command> instead of <Control Command> every mute playlist in the entire session will be deactivated, even on hidden tracks. |
Mute button mutes all tracks? | Bill0287 | Pro Tools M-Powered (Win) | 12 | 12-11-2022 02:20 PM |
turning looping on and off during playback? | George DAWs | Tips & Tricks | 1 | 12-09-2013 11:49 AM |
Pro Tools mutes playback when edit window is clicked Please help | Yaron | Pro Tools M-Powered (Win) | 4 | 03-18-2009 08:26 AM |
002 mute light not turning off | arbyis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-08-2008 07:42 PM |
Turning off "auto mute" | gillesmorneault666 | Tips & Tricks | 8 | 09-30-2006 10:56 AM |
