This is a strange bug that I've had ever since installing PTMP 8.0. It has persisted thru each CS update and continues with 8.0.1
This will happen even with a newly created blank session. If the edit window is minimized, and I attempt to save a session, the CPU usage will jump to near 100% (as displayed using Windows Process Explorer - the PT System Usage window does not display any overloads). The keyboard does not respond to commands in PT, and most menus are greyed out, besides File, Window and Help. In the File menu, only Exit is not disabled. If I restore the Edit window by clicking on the restore window button on the window's title bar, the CPU load immediately drops back to normal, and normal function of the program resumes. If I close the edit window without restoring it, PT will have to be closed via the task manager. If I display a menu or click on a window title, the CPU usage will drop to normal, but will return to maxed out as soon as I release the widget. This problem occurs when saving both to the local system drive and an external firewire drive. I just installed quicktime and trashed my prefs.. no changes. It's not a huge huge deal, i've learned to not minimize the edit window, but this bug really seems like it ought to be sorted out. I can't believe i'm the only one who has had this problem. WinXP SP3, IE7 (occurred with IE6 as well). only RTAS plug ins i have are the included ones from digi design and some demo Massey plug ins. I also have the fxexpansion VST wrapper and a few free vsts wrapped.. but like i said, this occurs on a totally blank, newly created session. Here is a screen shot: http://img23.imageshack.us/img23/5615/ptoverload.jpg < Processor > Model: Intel(R) Xeon(TM) CPU 3.00GHz Speed: 3GHz Cores per Processor: 1 Unit(s) Threads per Core: 2 Unit(s) Integrated Data Cache: 2x 16kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 lines per sector L2 On-board Cache: 2x 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 lines per sector < Computer > Mainboard: Dell 0XC838 BIOS: Dell A06 09/12/2005 Bus(es): X-Bus PCI PCIe IMB USB FireWire/1394 i2c/ SMBus Multi-Processor (MP) Support: No Multi-Processor Advanced PIC (:Yes Total Memory: 2GB ECC DIMM Registered DDR2 < Chipset > Model: Dell Precision 470 Front Side Bus Speed: 4x 200MHz (800MHz) Total Memory: 2GB ECC DIMM Registered DDR2 Memory Bus Speed: 2x 200MHz (400MHz) < Memory Module(s) > Memory Module: Infineon (Siemens) 72T64000HR5A 512MB ECC DIMM Registered DDR2 PC2-3200R DDR2-400 (3-3- 3-8 2-11-3-2) Memory Module: Micron 18HTF6472DY-40EB2 512MB ECC DIMM Registered DDR2 PC2-3200R DDR2-400 (3-3-3-8 2- 11-3-2) Memory Module: Infineon (Siemens) 72T64000HR5A 512MB ECC DIMM Registered DDR2 PC2-3200R DDR2-400 (3-3- 3-8 2-11-3-2) Memory Module: Micron 18HTF6472DY-40EB2 512MB ECC DIMM Registered DDR2 PC2-3200R DDR2-400 (3-3-3-8 2- 11-3-2) < Video System > Video Adapter: NVIDIA Quadro PCI-E Series (PS2.0, VS2.0 252MHz, 64MB DDR 2x405MHz, PCIe 1.00 x16) < Storage Devices > ST3300831A (300GB, ATA100, 3.5:279GB (D:) ST380013AS (80GB, SATA150, 3.5:75GB (C:) ST3160023A (160GB, FireWire/13:149GB (H:) PIONEER DVD-RW DVR-110D (ATA6:N/A (F:) ZYRADYP NGPYR85AN0 (SCSI, BD-R:N/A (G:) Disk: N/A (I:) < Logical Storage Devices > 300 GB (D:): 279GB (FAT32) @ ST3300831A (300GB, ATA100, 3.5", 8MB Cache) Hard Disk (C:): 74GB (NTFS) @ ST380013AS (80GB, SATA150, 3.5", NCQ, 8MB Cache) Optical Drive (F:): N/A @ PIONEER DVD-RW DVR-110D (ATA66, DVD+- RW, CD-RW, 64kB Cache) Optical Drive (G:): N/A @ ZYRADYP NGPYR85AN0 (SCSI, BD-R, HD-DVD- R, DVD+-R-DL, CD-R) Optical Drive (I:): N/A @ Disk Projects (H:): 149GB (HFSJ) @ ST3160023A (160GB, FireWire/ 1394, 3.5", NCQ) < Peripherals > LPC Hub Controller 1: Intel 82801EB/ER (ICH5/ICH5R) LPC Interface Bridge LPC Legacy Controller 1: SMSC EMC2700LPC Audio Device: Dell SoundMAX Integrated Digital Audio Audio Codec: Analog Devices 0074h Audio Device: VIA M Audio Delta-44 Serial Port(s): 2 Parallel Port(s): 1 Disk Controller: Dell Precision 470 Disk Controller: Dell Precision 470 USB Controller 1: Dell Precision 470 USB Controller 2: Dell Precision 470 USB Controller 3: Dell Precision 470 USB Controller 4: Dell Precision 470 USB Controller 5: Dell Precision 470 FireWire/1394 Controller 1: 3812 TSB82AA2 IEEE-1394b Link Layer Controller SMBus/i2c Controller 1: Intel 801xx/63xx SMBus < Network Services > Network Adapter: Intel(R) PRO/1000 MTW Network Connection - Packet Scheduler Miniport (Ethernet, 10Mbps) Network Adapter: ADMtek ADM8511 USB To Fast Ethernet Converter - Packet Scheduler Miniport < Power Management > Mains (AC) Line Status: On-Line < Operating System > Windows System: Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance: x86 if it helps the engineers find the problem, here's a snapshot of the thread stack. It's the Protools M-Powered.exe thread which has got the problem Quote:
Similar behavior, but mine "only" goes to 52%. Stays there till I un-minimize the window.
SiSoftware Sandra Computer Model : Gigabyte EP35-DS3L Workgroup : xxxxxx Host Name : e8400 User : xxxx Processor Model : Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz Speed : 3GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing Computer Mainboard : Gigabyte EP35-DS3L BIOS : Award (Phoenix) F5 07/16/2008 Bus(es) : X-Bus PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 2GB DIMM DDR2 DDR3 Chipset Model : Giga-Byte P35/G33/G31 Processor to I/O Controller Front Side Bus Speed : 4x 333MHz (1.33GHz) Total Memory : 2GB DIMM DDR2 DDR3 Memory Bus Speed : 2x 400MHz (800MHz) Memory Module(s) Memory Module : Corsair CM2X1024-6400C4 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X1024-6400C4 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Video System Video Adapter : NVIDIA GeForce 8400 GS (16 SP 1.4GHz, 512MB DDR2 2x500MHz, PCIe 1.00 x16) Graphics Processor Adapter : NVIDIA GeForce 8400 GS (8SP 1.4GHz, 511.7MB 2x500MHz) Storage Devices ST3320620NS (320GB, SATA150, 3.5", NCQ, 16MB Cache) : 298GB (G:) (H:) (I:) ST3320620AS (320GB, SATA300, 3.5", NCQ, 16MB Cache) : 298GB (C:) (D:) (E:) TSSTcorp CDDVDW SH-S223F (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) Logical Storage Devices system320AS (C:) : 78GB (NTFS) @ ST3320620AS (320GB, SATA300, 3.5", NCQ, 16MB Cache) data (D:) : 117GB (NTFS) @ ST3320620AS (320GB, SATA300, 3.5", NCQ, 16MB Cache) archive (E:) : 103GB (NTFS) @ ST3320620AS (320GB, SATA300, 3.5", NCQ, 16MB Cache) system320NS (G:) : 59GB (NTFS) @ ST3320620NS (320GB, SATA150, 3.5", NCQ, 16MB Cache) data320 (H:) : 117GB (NTFS) @ ST3320620NS (320GB, SATA150, 3.5", NCQ, 16MB Cache) archive320 (I:) : 122GB (NTFS) @ ST3320620NS (320GB, SATA150, 3.5", NCQ, 16MB Cache) Optical Drive (F:) : N/A @ TSSTcorp CDDVDW SH-S223F (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Giga-Byte (ICH9) LPC Interface Controller LPC Legacy Controller 1 : ITE IT8718F Audio Device : Giga-Byte (ICH9) HD Audio Controller Audio Device : VIA M Audio Delta-44 Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : Giga-Byte (ICH9) 2 port Serial ATA Storage Controller 1 Disk Controller : Giga-Byte (ICH9) 2 port Serial ATA Storage Controller 2 Disk Controller : Giga-Byte JMB368 IDE Controller USB Controller 1 : Giga-Byte (ICH9) USB Universal Host Controller USB Controller 2 : Giga-Byte (ICH9) USB Universal Host Controller USB Controller 3 : Giga-Byte (ICH9) USB Universal Host Controller USB Controller 4 : Giga-Byte (ICH9) USB2 Enhanced Host Controller USB Controller 5 : Giga-Byte (ICH9) USB Universal Host Controller USB Controller 6 : Giga-Byte (ICH9) USB Universal Host Controller USB Controller 7 : Giga-Byte (ICH9) USB Universal Host Controller USB Controller 8 : Giga-Byte (ICH9) USB2 Enhanced Host Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP LaserJet 1020 (600x600, USB) Network Services Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 Performance Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
well i'm glad at least one other person has this issue.. it seems like the only common hardware we have is the delta 44. I imagine you only see you cpu jump to 50% because you have a dual core.. i bet one of the CPUs is maxed out
the weird thing is, even though the cpu meter says 100% usage, the computer responds normally when using other programs.. it's not as if the whole computer is bogged down. |
Yeah - and I still think there are window "focus" issues. I still see larger than normal CPU usage when I do things like edit on the score etc. 20% jumps and that sort. Maybe something with the new graphics or???
I saw some threads awhile back talking about similar issues (window fucus and CPU) http://duc.digidesign.com/showthread...=249755&page=1 http://duc.digidesign.com/showthread...gh+cpu&page=43 But dont know if this is still on a list for fixes or is considered fixed with 8.01??? |
hmm yeah i wonder if it's part of a larger problem
I also just experienced.. if the program is in the bogged down state, and then you try to shut down the program with the session loaded, you have to kill the whole program via the task bar |
anyone else with this problem? Can anyone at digidesign confirm it's a known problem.. or make it known if it's not? :)
Can someone let me know if this is known or something particular to us few?
"But dont know if this is still on a list for fixes or is considered fixed with 8.01??? " |
it's definitely not fixed in 8.0.1
![]() Quote:
![]() You and I both have NVIDIA graphics - wonder what an ATI would do? Have heard unconfirmed rumors about differences between ATI/NVIDEA but cant teel if that is old news, a guess, or ??? |
![]() Quote:
![]() ![]() If you need or expect direct technical assistance from Digidesign, you should contact them... directly. ![]() For what it's worth, I do not have this problem with any of the 8.x versions, and I have the NVIDIA GeForce 7600 GT.
HDN jumps to high CPU usage | propower | Pro Tools HDX & HD Native Systems (Mac) | 1 | 09-30-2013 11:00 PM |
PT 9.0.1 Edit window view jumps forward | collinsylex | macOS | 2 | 02-10-2011 01:58 PM |
pod farm platinum iLok no sound unless plugin window minimized | Jenk2k | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-16-2010 06:27 AM |
Edit window and cpu usage | Trazan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 03-27-2009 12:05 PM |
CPU usage jumps up while doing nothing!! | Andrew B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-18-2003 12:14 PM |
