hi there- has anybody else encountered this problem? my 002 rack mute light will not switch off. any help is greatly appreciated.
Does this happen in standalone and also when running Pro Tools?
Can you hear audio even though the light won't go off? Also post your system info including software versions etc. it helps Digi and the rest of the gang here when trying to help.
I work with amazing people who do incredible things. Founder of the Expert Sites. |
Sounds like the power harness issue to me. Does it also make clicking sounds? Will Protools open or does it say hardware not found? Reseating the harness is simple on the rack version. Just remove the top cover. The PSU is on the right side(with front facing toward you). Follow the wire bundles to 3 white plastic/nylon connectors. Use a small screwdriver to lift the locking tab and pull/reseat each connector 5-6 times to scrape thru the oxidation on the pins. Odds are better than 50/50 that you will be back up and woring.
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
I'm sure this happened to every person that bought an 002R (MYSELF INCLUDED). albee1952's solution will work. Amazingly, I don't even keep the screws on the top of my unit any more, just so I can open it on a regular basis.
![]() Quote:
cheers |
Good advice but don't spray Pro Gold on the parts(it can raise hell). Instead, spray it on foam swaps(like for cleaning VCR heads) and wipe onto the pins.
Turning off Mute playback, and only mutes? | Farmer Dave | macOS | 4 | 02-24-2014 01:27 PM |
Turning off "auto mute" | gillesmorneault666 | Tips & Tricks | 8 | 09-30-2006 10:56 AM |
Only getting mute light!!! | Devion1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-08-2005 06:12 AM |
Red Light & Speaker Mute | henrygod | Tips & Tricks | 1 | 01-11-2005 04:36 PM |
002 dead except for mute light | roman brow | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-14-2003 06:19 AM |
