Hi, i have the monitors setup and both are on and working but this may be a dumb question.
How can i get the monitors to not be the same thing? I want to have the edit in the right and mix in the left window. thanks and i've looked on the DUC but didn't find much. |
you need to set that up in your windows display preferences - you should see the option to designate each monitor separately - in some cases you might need manufacturer drivers for this -
Shy, this is more of a Windows question, but... Assuming that Windows recognizes both monitors and your graphics card doesn't require specialized software...
--> Right-click on the desktop, choose "properties". On the "Settings" tab, look toward the bottom for a checkbox "Extend my desktop onto second monitor"... Make sure it's checked and adjust settings by clicking on the monitor "1" or monitor "2" icons... Hope this helps.
Windows XP Pro SP3 & Vista Ultimate SP1 / 002R v8.0 w/ MPT2 AMD X2 4800+ Dual Core / 1000 FSB / 4 GB RAM www.wolfskinrecords.com www.voodoopilot.com |
ok i got it working but can't drag the mix window to one of the monitors, i can get the whole pt window to go over but i'm trying to get the edit window in one and the mix in the other. thanks so far.
shynomi,
You don't drag by the titlebar..use the double arrow sizing thingy to "extend". I was just learning this last week, courtesy of Shawn ( spkgtr) ... good luck,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
ahh gotcha. it works now. thanks
Dual monitor vs single monitor setup | Whasssaaahhh | Pro Tools 9 | 23 | 03-17-2014 02:24 PM |
Still on Dual monitor setup | gerax | Pro Tools TDM Systems (Win) | 2 | 07-07-2006 01:51 PM |
Dual LCD monitor setup advice | Ruben_B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-16-2005 05:05 PM |
Dual monitor setup questions | kjax | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-17-2002 01:09 AM |
Anyone Using Dual Monitor Setup For Win98? | Chad Bumstead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 08-14-2000 11:25 AM |
