Old 09-09-2015, 05:26 AM
Terry Wetzel Terry Wetzel is offline
Default Blue Screen again and again!`
Hi. This may or not be a big issue, and I seem to be able to simply get around it by turning off the power to my equipment, waiting the prescribed 10 seconds and turning it back on,about every third time I shut every thing down, my pc blue screens! Is it something I should worry about or just another anomaly that there is no solution or reason for? If it truly is a sign of impending doom then why does just powering down and powering up make it go away? I'm on pt's 9, Win 7 32 bit. My current interface is a Project mix I/0but this also happens when I use my Scarlett 2i4. Any advice from experts ?
Old 09-09-2015, 07:56 AM
musicman691 musicman691 is online now
Default Re: Blue Screen again and again!`
Sad to say but I think you're looking at the last days of that computer, especially when it starts going intermittent like this. Could well be a power supply problem.
Jack
QAPLA!
Old 09-09-2015, 08:06 AM
justus1900 justus1900 is offline
My computer was blue screening and I found out it was a problem with the RAM, I switched and reseeded the RAM sticks and that fixed it for a little while but I ended up sending the RAM in and getting new RAM for free and that fixed my problem.
Producer/Engineer/Musician
RIAA Platinum Sales Award: Lisa Stansfield "Affection"
Main:
Model: Dell 5750 Precision Workstation
OS: Windows 10 Pro 64bit
CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz,
Memory:32GB, 2X16GB,DDR4 2933Mhz Non-ECC
OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSDAVID Fast Track C400
AVID Pro Tools 2021.3.1
JBL LSR4328P 8"
JBL LSR310S 10 inch Powered Studio Subwoofer*
Yamaha HS50M Studio Monitors
Alesis Elevate 3 Studio Monitors
M-Audio Axiom 61 Midi Controller
Old 09-09-2015, 01:10 PM
Emcha_audio's Avatar
If it blue screens it usually means that there's been a driver error. Even more so if you're able to boot it while the equipment is off and it boots without a blue screen, then you should probably reinstall the drivers of your hardware.
Manny.
Wave-T.com
Old 09-09-2015, 01:15 PM
junkgear's Avatar
junkgear junkgear is online now
Could be anything. Bad RAM could definitely be the culprit. A failing power supply can also cause all kinds of issues. The motherboard itself could have an intermittent connection. If it is something heat related, that could be why turning it off for a while helps a bit.
To start, try unplugging any cables, blow out any dust and reconnect them. Same with the RAM and any add on cards; unplug, dust and plug back in.
Will
System Details
Old 09-09-2015, 01:24 PM
This just reminded me of something - if the computer has a fan clean out all the dust bunnies in and around it. Also check to see if said fan is still running; if it's making any rattling noise you'll have to replace the fan. Generally fan rattling is the bearings going bad.
Jack
QAPLA!
Old 09-09-2015, 02:29 PM
And yes, constant BSOD points to a serious problem of some kind. RAM is one suspect, as is the power supply. I would at least open the case(with everything shutdown and the power cable unplugged), and reseat every card, all the RAM and any cables and connectors inside
But its also possible that maybe Windows has become corrupted. If you have been saving drive images, I would check the desktop for anything that should be saved(and save to any other drive for later retrieval), and then restore Drive C: from a recent image. If you have not been saving drive images......GRRRRR You may find yourself needing to reformat and start with a clean install of everything(ugh!!!).
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 09-09-2015, 08:10 PM
You can use this app
The download link is near the bottom. Get the zip version, no need to do a full install.
It will let you view all your crashlogs. It is going to be a bit in depth, but if it is a driver, it will tell you. If it is something more complex (computer hardware) it will be a bit more cryptic and maybe not be of much help. but if its a driver problem, it should be an easy fix.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 9900k
Win 10
Old 09-10-2015, 05:37 AM
Thanks guitardom and everyone who responded to my post. Wow! I was scared that the blue screen was occurring so often. Now I'm really scared! It appears to me that this well could be a driver issue since I recently changed interfaces and did download the proper drivers. If memory serves it wasn't happening before I did that. I'm referring to the project mix I/o. If it turns out to be something else I will be at a total loss since I won't be able to understand the diagnostic analysis. I'll try cleaning everything first and if that doesn't solve the problem I think I'd better take it to a computer repair shop. ,
Old 09-10-2015, 05:50 AM
Is this a desktop or laptop? And how recent is the machine? Whether a repair shop can fix it or not depends on those factors.
Jack
QAPLA!
Blue Screen 10.3.5 Shatzer Windows 1 04-29-2013 09:53 AM
blue screen vikingthor VENUE Live Sound Systems 0 03-01-2011 07:40 AM
VxD and the Blue Screen quartermayne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-16-2002 07:25 PM
The Blue Screen RDOG 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-18-2000 04:14 PM
Blue screen mark king 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-26-2000 11:48 PM
