Old 06-16-2021, 09:04 AM
kiddipalli kiddipalli is offline
Question Menu item naming: "Delete" vs "Delete..."
Hi all,
Just wanted to post a strange bug and wonder if anyone can replicate.
I use custom keyboard shortcuts a lot in PT on MacOS and I made a shortcut for track delete today.
I´m working on several sessions (all created on the same machine and system on the same day) While switching between sessions I noticed that my new shortcut wouldn´t work in all of them. When I went into Menu>Track I saw that PT sometimes names the menu command "Delete" and other times it´s named "Delete...". I´ve never seen this before as I´ve not been paying much attention to it until now.
For those who don´t know, creating a custom shortcut in MacOS requires you to write out the menu command exactly as it is in the software so this is an inconveniance (although a minor one)
I´m using PT 2021.3.0 on Mac OS 10.14.6
If something is impossible, it will just take a little longer to finish.
Old 06-16-2021, 09:54 AM
daeron80 daeron80 is offline
Default Re: BUG REPORT: Menu item naming
Wow...
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 06-18-2021, 05:58 AM
Prabha Prabha is offline
Lucky you! at least you can create shortcut macros in OS for PT! The windows version of PT is totally crippled in this regard.
(sorry for the rant)
PC i79700K 4.8Ghz 32Gb ram Nvidia1050
Win 10 64
SSL MX4
Old 06-18-2021, 07:17 AM
Marsdy Marsdy is offline
Originally Posted by kiddipalli View Post
Hi all,
I’d like to know what those three dots mean. Quite a few menu items have them, not just delete.
Dave Marsden
UK
Old 06-18-2021, 07:37 AM
I think I´ve figured it out...
If said command will be followed by a prompt window, it will show the three dots after.
So if the delete function will delete the track without question = no dots
If the delete function is going to give me options before deletion = Three dots
Old 06-18-2021, 07:43 AM
its2loud its2loud is offline
I came across this phenomenon when I was doing the same thing. The ellipsis occurs when there is audio or midi on the track. I believe I just made two keyboard shortcuts for both with and without the ellipsis and this fixed the issue.
Old 06-18-2021, 08:07 AM
Yeah, I did just that and it works great!
Thanks for the advice.
Old 06-18-2021, 08:15 AM
midnightrambler midnightrambler is online now
Yes I've done the same thing. There was a time when I went mad for making shortcuts this way but I found myself getting tripped up when moving rigs or updating OS so I weaned myself off it. Would still love an actual built-in shortcut for "Show/Hide Color Palette"...
Old 06-18-2021, 10:01 AM
Sonopolis Sonopolis is offline
This actually is the Apple UI design philosophy. Try the -menu, now hit the ALT key. The dots disappear. Wouldn't that be nice for some dialogues?
Old 06-18-2021, 12:04 PM
That makes sense, good call! The dots appear after MIDI Editor for example which obviously takes you to a new window.
Dave Marsden
UK
New to PT: Advanced Trial doesn't have the Setup|Hardware menu item PatAzzMusic Pro Tools 2020 3 04-27-2020 11:37 AM
Missing Menu Item Cal D Windows 2 07-12-2015 05:27 PM
To Delete or Not to Delete...that is the question DonaldM General Discussion 14 11-06-2013 04:52 AM
Keyboard shortcuts - duplicate menu item names jeremyroberts Pro Tools TDM Systems (Mac) 0 11-18-2005 02:04 PM
In case delete region, my PT 5.1.3 delete all regions on track. What is it? kwarkot Post - Surround - Video 0 12-04-2002 12:38 AM
